Hello,
I am using Fatlib16's AnalogBinLogger to record a piezo attached to analog 0 at 8 kHz which i am doing successfully.
I would like to initiate and stop recording (sending data to SD card) by using a push button to allow the device to be portable. I will then convert the bin to csv file post recording.
I currently have the push button attached to digital pin 2.
I have edited the following sections to the code:
// Pin definitions.
// Digital pin to indicate an error, set to -1 if not used.
// The led blinks for fatal errors. The led goes on solid for SD write
// overrun errors and logging continues.
const int8_t ERROR_LED_PIN = -1;
// SD chip select pin.
const uint8_t SD_CS_PIN = 10; // Needs to be set to pin 10 for adafruit datalogger.
// Defining switch's to initiate and end recording.
const int8_t recordPin = 2;
int8_t recordVal;
void setup(void) {
if (ERROR_LED_PIN >= 0) {
pinMode(ERROR_LED_PIN, OUTPUT);
//Set digital pin 2 as input
pinMode(recordPin, INPUT);
// Read the first sample pin to init the ADC.
analogRead(PIN_LIST[0]);
Serial.print(F("FreeStack: "));
Serial.println(FreeStack());
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
if (!sd.begin(SD_CS_PIN, SD_SCK_MHZ(50))) {
sd.initErrorPrint();
fatalBlink();
void loop(void) {
// Read any Serial data.
do {
delay(10);
} while (Serial.available() && Serial.read() >= 0);
Serial.println(F("type:"));
Serial.println(F("c - convert file to csv"));
Serial.println(F("d - dump data to Serial"));
Serial.println(F("e - overrun error details"));
Serial.println(F("Press Switch - record ADC data"));
while(!Serial.available()) {
SysCall::yield();
char c = tolower(Serial.read());
digitalWrite(ERROR_LED_PIN, LOW);
do {
delay(10);
recordVal = digitalRead(recordPin);
if (recordVal == HIGH) {
logData(); // Change to 1st digital switch for operating code(
} else if (c == 'c') {
binaryToCsv(); //Change to 2nd digital switch
} else if (c == 'd') {
dumpData();
} else if (c == 'e') {
checkOverrun();
Serial.println(F("Invalid entry"));
#else // __AVR__
#error This program is only for AVR.
#endif // __AVR__
Any help would be really appreciated, thanks.
