Static Methods for Libraries
Is it possible to have static methods in libraries or classes? Similar to what java does. For example, in java you can call the math class: Math.pow(3,2);
Yes. You can create a static method in a class, and call that method from the sketch, or from other methods in the class. Calling a static method in a class is done using the scope resolution operator (::slight_smile: not the member operator (.).
Thanks. What is the syntax?
What is the syntax?
For what? For declaring a static function in a class? For calling the static function from the class? For calling the static function from the sketch?
how about all of the above?
OK.
class stupidStuff
   stupidStuff();
   static void someFunction(); // Takes no arguments
stupidStuff::stupidStuff()
   stupidStuff::someFunction();
#include "stupidStuff.h"
Thank you PaulS =)
