Static variable class member
HI All
I am doing some practice tests with classes. I wrote this simple class:
class Person{
private:
  String _name;
  int _age;
  int _size;
public:
  Person(){
    _size = 48;
  Person(String name){
    _name = name;
    _size = 48;
    Person(String name, int size){
    _name = name;
    _size = size;
 int setName(String name){
    _name = name;
  int setAge(int age){
    _age = age;
  int setSize(int size){
    _size = size;
  void showData(){
    Serial.print("this person's name is : ");
    Serial.println(_name);
    Serial.print("this person's age is : ");
    Serial.println(_age);
    Serial.print("this person's size is : ");
    Serial.println(_size);
Person john("John");
john.setAge(45);
john.showData();
Now, I would like the private variable _size to be the same for all objects of the class. I have tried to use the keyword static in front of it but it throws errors.
My understanding is that a static variable would act like a global variable for the class.
I may want to use it as a constant in certain scenarios or as a variable in others, but it has to be the same for all the objects of the class.
Any suggestions?
Cheers.
Try this:
class Person{
private:
  String _name;
  int _age;
  static int _size;
public:
  Person(){
    _size = 48;
    _name = name;
    _size = 48;
    _name = name;
    _size = size;
    _name = name;
    _age = age;
    _size = size;
  void showData(){
int Person::_size=0;
john.setAge(45);
john.showData();
please show the code where you use "static"
please see belwo:
@wildbill this is exactly what I was trying but it throws errors...
inline static int _size;
Also in your Wokvi you have a several errors "no return in function declared non-void" in your calss methods setName, setAge and setSize
think it needs to be inline..
add inline before static..
good luck.. ~q
@wildbill , apologies, you were right I missed the line "int Person::_size=0;" of your code
@Delta_G Thanks
this works! So static variables HAVE to be defined outside the class ?
I was trying to have it initialized by the constructor. I have noticed that if I add
then also the constructor initialization works... I will paste the code and output below...
@b707 you are right, strangely it does not given an error about that and the functions work as expected though
class Person{
private:
  String _name;
  int _age;
  static int _size;
public:
  Person(){
    _size = 48;
    _name = name;
    _size = 48;
    _name = name;
    _size = size;
    _name = name;
    _age = age;
    _size = size;
  void showData(){
john.setAge(45);
john.showData();
output
This person's name is : John
this person's age is : 45
this person's size is : 48
Thank you all😊
It depends on Arduino IDE settings, that are different for a different boards. When I selected a Raspberry Pi RP2040 in order to compile your code - it throw me that errors.
@b707
@Delta_G
got it! thanks! :slight_smile:
