Hello,
I have a program that works on computer that takes in a class through a template and puts a function from it into a vector to use later, but I need to use std::funciton.
arduinoSTL has functional, but it does not have the std::function in it? How can I use it to do this?
code
#include <Streaming.h>
#include <ArduinoSTL.h>
using namespace std;
struct typeA
public:
int data = 0;
void update()
Serial << "hello, my data is " << data << "\n";
struct typeB
float data = 0;
void update()
Serial << "hi, my data is " << data << "\n";
class typeList
std::vector<std::function<void()>> items; //This does not work
public:
template <class Item>
void addItem(Item& item)
// Care: life time of item should be bigger than this instance
items.push_back([&]() { item.update(); });
void doWork()
for (auto& f : items) //As a result neither does this
f();
int main()
typeA aThing;
typeB bThing;
typeList listThings;
aThing.data = 128;
bThing.data = -3.234;
listThings.addItem(aThing);
listThings.addItem(bThing);
listThings.doWork();
return 0;
/* add setup code here */
main();
/* add main program code here */
