Hello,
I am fairly new to arduino and electronics, I am trying to move a stepper motor based on the serial input. Below you can find the code I wrote for testing, I built my code on the Adafruit dual sensor example. Ultimately, I am trying to achieve continous movement of 2 stepper motors and interrupt the movement when the distance the sensor reads is equal to the distance from the serial. Is this achievable with stepper motors? If not, I am open to any suggestions?
#include "Adafruit_VL53L0X.h"
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
// set the pins to shutdown
#define SHT_LOX1 7
#define SHT_LOX2 6
#define xdirPin 3
#define xStep 2
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
// this holds the measurement
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
const int stepsPerRev = 200;
void setID() {
// all reset
digitalWrite(SHT_LOX1, LOW);
digitalWrite(SHT_LOX2, LOW);
delay(10);
// all unreset
digitalWrite(SHT_LOX1, HIGH);
digitalWrite(SHT_LOX2, HIGH);
delay(10);
// activating LOX1 and resetting LOX2
// initing LOX1
if (!lox1.begin(LOX1_ADDRESS)) {
Serial.println(F("Failed to boot first VL53L0X"));
while (1);
delay(10);
// activating LOX2
delay(10);
// initing LOX2
if (!lox2.begin(LOX2_ADDRESS)) {
Serial.println(F("Failed to boot second VL53L0X"));
while (1);
int read_x_sensor() {
lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
// print sensor one reading
if (measure1.RangeStatus != 4) { // if not out of range
return measure1.RangeMilliMeter;
return -1; // error value
void initApp() {
pinMode(SHT_LOX1, OUTPUT);
pinMode(SHT_LOX2, OUTPUT);
Serial.println(F("Shutdown pins inited..."));
Serial.println(F("Both in reset mode...(pins are low)"));
Serial.println(F("Starting..."));
// wait until serial port opens for native USB devices
while (!Serial) { delay(1); }
pinMode(xStep,OUTPUT);
pinMode(xdirPin,OUTPUT);
initApp();
setID();
static int distance = 0;
// Check if there is serial input
if (Serial.available() > 0) {
targetDistance = Serial.parseInt();
distance = read_x_sensor();
if (distance != -1) { // if a valid reading is obtained
if (distance > targetDistance) {
digitalWrite(xdirPin,LOW);
for(int x = 0; x < 5; x++) {
digitalWrite(xStep,HIGH);
delayMicroseconds(500);
digitalWrite(xStep,LOW);
} else if (distance < targetDistance) {
digitalWrite(xdirPin,HIGH);
for(int x = 0; x < 20; x++) {
Serial.println("Error reading sensor.");
delay(100);
