I am having trouble with making a stepper motor move at equal speeds in both directions. I have an RC transmitter and receiver successfully moving the stepper motor back and forwards. However, one direction does not move as fast as the other. when moving the joystick left it has 5 speeds, which is correct. However, moving the joystick to the right it only has the first three of those 5 speeds I've told it to do. I checked the pulses and having the joystick in the center is sending 1490, full left stick sends 892, full right stick sends 2091. I have fiddled around with changing pulse width to higher and lower values but the problem persists. I am pretty new to coding and don't exactly know what's going on. Any help would be wonderful
Thanks
//Define Pins
#define RCPin 2
#define DIR 17
#define STEP 16
//Set up time variables for Stepper motor
unsigned long previousMotorTime = millis();
long MotorInterval;
volatile long StartTime = 0;
volatile long CurrentTime = 0;
//Set up time variables for RC Read
volatile long Pulses = 0;
int PulseWidth = 0;
//RC Read Setup
pinMode(RCPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(RCPin), PulseTimer, CHANGE);
pinMode(DIR, OUTPUT);
pinMode(STEP, OUTPUT);
digitalWrite(STEP, LOW);
//Only save HIGH pulse lengths
if (Pulses < 2000){
PulseWidth = Pulses;
//Stepper motor speed, bigger MotorInterval is a slower speed.
if (PulseWidth >= 1400 && PulseWidth <= 1600){
digitalWrite(STEP, LOW); //Motor doesn't move if the joystick is near the midpoint
else if (PulseWidth < 1400){
digitalWrite(DIR, LOW);
MotorInterval = map(PulseWidth, 1000, 1400, 1, 5); //map the RC signal to the motor speed in reverse when the joystick is pulled down
else if (PulseWidth > 1600){
digitalWrite(DIR, HIGH);
MotorInterval = map(PulseWidth, 1600, 2000, 5, 1); //map the RC signal to the motor speed when the joystick is pushed forward.
//check if the MotorInterval time has elapsed and step the motor.
unsigned long currentMotorTime = millis();
if (currentMotorTime - previousMotorTime > MotorInterval){
digitalWrite(STEP, HIGH);
previousMotorTime = currentMotorTime;
//Function to measure the length of the pulses from the remote control
void PulseTimer(){
CurrentTime = micros();
if (CurrentTime > StartTime){
Pulses = CurrentTime - StartTime;
StartTime = CurrentTime;
The observed speed in one direction moves nearly twice the speed as the other direction. Each side should have 5 controllable speeds, the first three speeds on both sides match. But one side goes the extra 2 speeds while the other is stuck at speed 3.
Sorry about my lack of info, this is my first Arduino project :((
The motor will keep moving in the direction the stick is held until I return the stick on the transmitter to the middle, which is good as that's what I am wanting!
I am a little concerned with the time spent for mapping and the tight timing with 1 and 2 milliseconds.
What do you see if you reverse the checking order? Are the missing times switched around? This will give a clue as to whether the issue is with the timing of the if/ifelse ladder.
Added it now! The code does compile however the same issue is occurring. Additionally, the RPM appears to be slightly lower than before on both directions
I do not own an oscilloscope so I cannot do that suggestion sadly.
I used a Serial.print and the serial monitor to check those values, which are from 892-2091.
I thought the issue was that the full range of speeds available in the two directions was not the same, but that for the speeds that you had, the rates were equivalent in each direction.
Can you please characterize the nature of the problem with a bit more detail.
