(Apologies if this has been posted before but i am at a loss and looking for advice as to whats wrong)
Running ESP8266(LiLon NodeMCU V3)
Followed this guide:
This is the setup
And it just wont turn, check everything over and over and the website loads and click the buttons fine it shows in the Serial Monitor, only thing i have found is everything's getting hot like 70C + is that normal for a ESP8266?
Here is the code,
* Date: 9 july 2018
* Written by: Usman Ali Butt
* Property off: microcontroller-project.com
#include <ESP8266WiFi.h>
const char* ssid = "";
const char* password = "";
int Step = 5; //GPIO0---D1 of Nodemcu--Step of stepper motor driver
int Dir = 4; //GPIO2---D2 of Nodemcu--Direction of stepper motor driver
WiFiServer server(80);
delay(10);
pinMode(Step, OUTPUT); //Step pin as output
pinMode(Dir, OUTPUT); //Direcction pin as output
digitalWrite(Step, LOW); // Currently no stepper motor movement
digitalWrite(Dir, LOW);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address on serial monitor
Serial.print("Use this URL to connect: ");
Serial.print("http://"); //URL IP to be typed in mobile/desktop browser
Serial.print(WiFi.localIP());
Serial.println("/");
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
int i=0;
int value = LOW;
if (request.indexOf("/Command=forward") != -1) { //Move 50 steps forward
digitalWrite(Dir, HIGH); //Rotate stepper motor in clock wise direction
for( i=1;i<=50;i++){
digitalWrite(Step, HIGH);
delay(10);
delay(10);}
value = HIGH;
if (request.indexOf("/Command=backward") != -1) { //Move 50 steps backwards
digitalWrite(Dir, LOW); //Rotate stepper motor in anti clock wise direction
delay(10);
delay(10);}
value = LOW;
// Return the response
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<h1 align=center>Stepper motor controlled over WiFi</h1><br><br>");
client.print("Stepper motor moving= ");
if(value == HIGH) {
client.print("Forward");
client.print("Backward");
client.println("<br><br>");
client.println("<a href=\"/Command=forward\"\"><button>Forward </button></a>");
client.println("<a href=\"/Command=backward\"\"><button>Backward </button></a><br />");
client.println("</html>");
delay(1);
Serial.println("Client disonnected");
Serial.println("");
