Hi there,
I am a beginner in Arduino and need some help to do something that sounds simple but I can't find the solution in my readings.
I am controlling a bi-polar stepper motor (Nema 17 / 17HS13-1204S) with a DRV8825 Driver and Arduino Nano.
The motor should run in continuous, the speed is controlled by a potentiometer. There is a button controlling the direction (FORWbutton = Forward), a STOP Button and a general ON button. Everything is working fine with the code I could write.
I would like to add a parameter that would make the motor run at half of the speed determined by the pot for 1 second when it start (when ONButton turns HIGH) , then at normal speed.
I have found some code doing that with fixed speeds but I can not figure out how to do this when the speed is determined by a pot.
Is there a simple way to do this?
Here is the code I have now :
const int stepPin = 3;
const int dirPin = 2;
const int sleepPin = 4;
int customDelay,customDelayMapped; // Defines variables
const int FORWbuttonPin = 6;
int FORWbuttonState = 0;
const int ONbuttonPin = 7;
int ONbuttonState = 0;
const int STOPbuttonPin = 8;
int STOPbuttonState = 0;
// Sets the two pins as Outputs
pinMode(FORWbuttonPin, INPUT);
pinMode(ONbuttonPin, INPUT);
pinMode(STOPbuttonPin, INPUT);
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(sleepPin,OUTPUT);
digitalWrite(dirPin,HIGH); //Enables the motor to move in a particular direction
customDelayMapped = speedUp(); // Gets custom delay values from the custom speedUp function
// Makes pules with custom delay, depending on the Potentiometer, from which the speed of the motor depends
FORWbuttonState = digitalRead(FORWbuttonPin);
if (FORWbuttonState == HIGH) {
digitalWrite(dirPin, HIGH);
digitalWrite(dirPin, LOW);
STOPbuttonState = digitalRead(STOPbuttonPin);
if (STOPbuttonState == HIGH) {
digitalWrite(sleepPin, LOW);
digitalWrite(sleepPin, HIGH);
ONbuttonState = digitalRead(ONbuttonPin);
if (ONbuttonState == HIGH) {
if (ONbuttonState == HIGH && STOPbuttonState == HIGH) {
digitalWrite(stepPin, HIGH);
delayMicroseconds(customDelayMapped);
digitalWrite(stepPin, LOW);
// Function for reading the Potentiometer
int speedUp() {
int customDelay = analogRead(A0); // Reads the potentiometer
int newCustom = map(customDelay, 0, 1023, 5,300); // Convrests the read values of the potentiometer from 0 to 1023 into desireded delay values (300 to 4000)
return newCustom;
