Hey guys!
Alright guys! I think I almost got it!
I need to change the direction of a stepper motor with the help of an alternating switch (press it once, the do a number of steps, another and the same amount of steps in reverse)
I'm using these two lines of code, and I just need to mix them
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on the motor shield
Stepper myStepper(stepsPerRevolution, 12,13);
// give the motor control pins names:
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 9;
const int brakeB = 8;
const int dirA = 12;
const int dirB = 13;
int x = 0;
// set the PWM and brake pins so that the direction pins // can be used to control the motor:
pinMode(pwmA, OUTPUT);
pinMode(pwmB, OUTPUT);
pinMode(brakeA, OUTPUT);
pinMode(brakeB, OUTPUT);
digitalWrite(pwmA, HIGH);
digitalWrite(pwmB, HIGH);
digitalWrite(brakeA, LOW);
digitalWrite(brakeB, LOW);
// initialize the serial port:
// set the motor speed (for multiple steps only):
myStepper.setSpeed(100);
myStepper.step(-10800);
myStepper.step(10800);
This one has the amounts of steps I need, I just put it on a loop.
// for your motor
const int pwmA = 3;
int x = 0;
int inPin = 2; // the number of the input pin
int outPin = 4; // the number of the output pin
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
pinMode(inPin, INPUT);
pinMode(outPin, OUTPUT);
reading = digitalRead(inPin);
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
digitalWrite(outPin, state);
previous = reading;
and this one has a switch connected to a led and it works. one press and it on, another and it's off. It also already has all the intergers from the stepper loop.
Now, I just need a little help putting them together
Would you help a brother out?.
