stepper motor unresponsive..
Hey All, I'm new to Arduino so forgive me on any mistake i may have made.
after uploaded this sketch I'm only getting a slight vibrate from the stepper, its not responding to the encoder movements ... can anyone shed some light on the issue...
thanks
#include <AccelStepper.h>
//encoder/motor/driver setup
int easyDriverMicroSteps = 1;
int rotaryEncoderSteps = 75; //setps per rev on your encoder
int motorStepsPerRev = 200; //steps per rev on the motor
int MinPulseWidth = 50; //too low and the motor will stall, too high and it will slow it down
//these pins can not be changed 2/3 are special pins
int encoderPin1 = 2;
int encoderPin2 = 3;
int easyDriverStepPin = 4;
int easyDriverDirPin = 5;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
//1 means we are using a motor driver with the library
AccelStepper stepper(1, easyDriverStepPin, easyDriverDirPin);
void setup(){
  stepper.setMinPulseWidth(MinPulseWidth);
  stepper.setMaxSpeed(50000);
  stepper.setAcceleration(1000000000);
  stepper.setSpeed(50000);
  pinMode(encoderPin1, INPUT);
  pinMode(encoderPin2, INPUT);
  digitalWrite(encoderPin1, HIGH); //turn pullup resistor on
  digitalWrite(encoderPin2, HIGH); //turn pullup resistor on
  //call updateEncoder() when any high/low changed seen
  //on interrupt 0 (pin 2), or interrupt 1 (pin 3)
  attachInterrupt(0, updateEncoder, CHANGE);
  attachInterrupt(1, updateEncoder, CHANGE);
void loop(){
  //go to where the encoder was turned to.
  int stepsPerRotaryStep = (motorStepsPerRev * easyDriverMicroSteps) / rotaryEncoderSteps;
  stepper.moveTo(encoderValue * stepsPerRotaryStep);
  stepper.run();
  if(encoderValue != lastencoderValue){
    lastencoderValue = encoderValue;
    Serial.println(encoderValue);
void updateEncoder(){
  int MSB = digitalRead(encoderPin1); //MSB = most significant bit
  int LSB = digitalRead(encoderPin2); //LSB = least significant bit
  int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
  int sum  = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
   if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue ++;
  if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
  lastEncoded = encoded; //store this value for next time
I have never used accelstepper so I can't help with that part. I have just coded my steppers myself.
Can you post a diagram of how everything is wired up, especially the power supply for the motor.
...R
Your max speeds and max accelerations are probably too high, but you must declare
the constants as long, thus:
50000L
1000000000L
Too high an acceleration will cause mis-stepping from the get-go, too high
a max speed will cause mis-stepping as you take the actual speed past the limit
for the motor.
Thanks guys,
i rewired it all and everything worked perfect ! :smiley:
