Hi all,
Over the next few months im going to be putting together a time lapse rail for a DSLR camera. I've got a lot of it planned already, but am currently at a decision point with regards to motor. The basic hardware of this requires a slow moving carriage along a guide rail, similar to this.
http://uk.rs-online.com/web/p/linear-guides-rails/3113711/.
The carriage will hold a DSLR camera (weighing around a couple of kilos potentially) and may move along the rail at an incline of up to 45 degrees. For either motor choice, i'll be running a timing belt mechanism to shift the carriage along the rail.
The primary considerations of this are
- The mechanism requires a "move, stop, shoot, move, stop, shoot" process
- The whole rig must run on external power and run for a relatively long period (in the region of hours) between charges.
Ideally, id like to use a stepper motor as this covers off the ability to set the speed and do the "move/stop/shoot" process.
However, my concern is with the amount of power a stepper motor will take compared to a normal low RPM (15) geared DC motor. From what i have read on steppers, they require power to hold position whereas I could "pulse" a normal DC motor and it will rest un-powered without the carriage moving (have seen this done in other examples of timelapse rails but im not sure its as controllable as i need it to be).
All of the timing and movement will be ATMega driven.
I'm pretty new to the hardware side of things so if someone could recommend motors/power sources i would be extremely grateful.
My initial thoughts for DC motor are this one
And stepper motor (i know i need a controller too)
Many thanks
Mark
