For the last month I have been trying to learn the basics of C++, I can now do basic things but I'm still struggling with my project.
I am using a Mega 2560 with a A4988 Driver and a Nema 17 driving a lead screw to control a nozzle.
I have copied the code from a guide and slowed it down and reduced the amount of steps moved when the button is pressed as my project only requires it to turn 270 deg.
I would like the stepper to move back slowly to the home switch when turned on -
I have tried writing an if function in the setup but I don't seem to be having much luck, would anyone be able to help me out.
electro-jerry:
That is a very common requirement.
If you can be CERTAIN that the motor is always to right (say) of the limit switch then you need something like this in setup()
limitSwitchState = digitalRead(limitSwitchPin);
while (limitSwitchState == HIGH) { // assumes LOW when pressed
// code to move one step to the left
delay(timeBetweenSteps);
electro-jerry:
It seems to move faster during the homing loop than it does under the switch, not a problem just curious why?
Perhaps because of the time taken to execute the other lines of code in loop(). If you use the non-blocking code as illustrated in the second example in this Simple Stepper Code it will allow for the time taken on other activities.
You don't need Line 33
I need it to not be able to move behind the limit switch and only move forward from the limit switch by 1 revolution.
There are two issues here and I don't think I understand what you have in mind for either of them.
How (or when) does it move behind the switch?
If you want to limit how far the motor moves just keep count of the steps and stop when you get to the max.
The project is to control a nozzle for a display which the public will be able to control via the buttons. As as we know the public like to break things.
To reach the full movement I only require 1 revolution of the lead screw away from the home switch.
electro-jerry:
I understand that problem.
But how does your program allow anyone to move the motor out of range? In what circumstances can that happen? For example can someone manually move the motor to the wrong place?
The normal way to control a stepper motor is to establish the zero position at startup (you are doing that) and then keep count of the position as each step is taken and only allow it to move from (say) 0 to 200 steps.
if something can interfere with the motion so that the motor misses steps then, of course, the counting becomes meaningless.
electro-jerry:
Sorry for the delayed reply, i am unsure how I initialise these statements, should they be located before each 'if' statement?
It will be easier to understand what is in your mind if you make an attempt to include them in your code and then post the latest version of your program.
I'm not even sure what you mean by "these statements"
Sorry I really struggle to know the correct words to describe code related problems.
I have added
int stepCount;
int stepMin = 0;
int stepMax = 3000;
at the start before the set up.
and then added
if (stepCount > stepMax)
stepCount = stepMax;
if (stepCount < stepMin)
stepCount = stepMin;
at the end of the loop function. The sketch compiles but does not work as intended.
The aim would be that when switch is held down or pressed lots of times it will not exceed 3200 steps/ 360 degrees.
The full code showing the locations of this is also included below.
//Code adapted from stepper control guide !!!
#define DISTANCE 50
int StepCounter = 0;
int Stepping = false;
int limitSwitch = 4;
int stepCount;
int stepMin = 0;
int stepMax = 3200;
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
pinMode(2, INPUT); // move down and open nozzle
pinMode(3, INPUT); // move up and close nozzle
pinMode(limitSwitch, INPUT); //return home switch
Serial.begin(9600); //Used during construction to confirm the function of the switch
/*While statment/return to home function contributed
by (Robin2, 2017) via arduino forum*/
limitSwitch = digitalRead(4);
while (limitSwitch == HIGH)
digitalWrite(9, HIGH);
delayMicroseconds(500);
int buttonState = digitalRead(limitSwitch);
Serial.println(buttonState); //Used during construction to confirm the function of the switch
/*when switch state is changed motor moves
anti clockwise by the 'defined' distance*/
if (digitalRead(3) == LOW && Stepping == false)
Stepping = true;
/*when button state is changed motor moves
if (digitalRead(2) == LOW && Stepping == false)
digitalWrite(8, HIGH);
Stepping = true;
/*This defines the speed at which the steps are taken in
microseconds, e.g. 0.0005 seconds between each step */
if (Stepping == true)
StepCounter = StepCounter + 1;
if (StepCounter == DISTANCE)
StepCounter = 0;
Stepping = false;
You already have a variable called stepCounter in your program - what are you using that for?
I note, for example, that you set it back to 0 when the motor reaches the "DISTANCE". Why are you doing that? It seems to me that it would allow the motor to move in the same direction by another "DISTANCE" - wouldn't that be too far?
And, because I don't know what you are using stepCounter for I cannot say whether that is the variable you should be using in the piece of code I suggested.
You should not treat what I suggest as the exact final code to use. It was just intended to put an idea in your head so you could build the idea into your own code.
I have only included a limit switch at the bottom, this allow the stepper to know its home position. Once the home position is confirmed I had assumed the upper limit could be controlled by counting the number of steps.
