Hi, I have an Arduino Mega 2560 with an L298N and a Nema 17 stepper motor. What I am wanting to know is what I am doing wrong making a library for controlling the frequency and how long the stepper motor will be on? I am trying to use the stepper.h, stepper.cpp, Accelstepper.h, and Accelstepper.cpp files as an example, but I get this error:
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
Yes, the board is plugged up to the computer, but this message appears above that message:
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Users\\austin\\Documents\\Arduino\\libraries\\stepperTestLibrary" "C:\\Users\\austin\\Documents\\Arduino\\libraries\\stepperTestLibrary\\stepperTestLibrary.cpp" -o "C:\\Users\\austin\\AppData\\Local\\Temp\\arduino_build_519425\\libraries\\stepperTestLibrary\\stepperTestLibrary.cpp.o"
C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.cpp:13:1: error: prototype for 'stepperTest::stepperTest(int, int, int, int)' does not match any in class 'stepperTest'
stepperTest::stepperTest(int SMPin1, int SMPin2, int SMPin3, int SMPin4){
In file included from C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.cpp:11:0:
C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.h:15:7: error: candidates are: constexpr stepperTest::stepperTest(stepperTest&&)
class stepperTest{
C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.h:15:7: error: constexpr stepperTest::stepperTest(const stepperTest&)
C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.h:19:1: error: stepperTest::stepperTest(uint8_t, uint8_t, uint8_t, uint8_t)
stepperTest(uint8_t SMPin1, uint8_t SMPin2, uint8_t SMPin3, uint8_t SMPin4);
C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.cpp:29:6: error: prototype for 'void stepperTest::runStepper(int, int)' does not match any in class 'stepperTest'
void stepperTest::runStepper(int frequency, int duration){
C:\Users\austin\Documents\Arduino\libraries\stepperTestLibrary\stepperTestLibrary.h:21:6: error: candidate is: void stepperTest::runStepper(uint8_t, uint8_t)
void runStepper(uint8_t frequency, uint8_t duration);
I don't know what this means and I have tried to fix the library several times, but remained unsuccessful. Any help with fixing this library based on this error message would be great. The purpose of this library is to make (hopefully) some stepper motor music. I used a test to figure out how the speed had to do with the musical pitch and it turned out successful. According to my test with the Accel library, the RPM has to do with the frequency of the musical pitch. Here it is:
#include <AccelStepper.h>
#include <MultiStepper.h>
// initialize the stepper library on pins 8 through 11:
AccelStepper myStepper(AccelStepper::FULL4WIRE, 22, 23, 24, 25);
myStepper.setMaxSpeed(1000);
myStepper.setSpeed(440);
myStepper.runSpeed();
-Thanks,
Austin
stepperTestLibrary.zip (2.3 KB)
