Steps for using Softwareserial with attiny
I've successfully used the atTiny before, but I need to see the values of the sensors I am using and I am trying to do this using SoftwareSerial and not having any luck.
Here are my steps (based on the HLT description/wiring: http://hlt.media.mit.edu/?p=1695)
I am using a Duemilanove as Arduino ISP, then burning bootloader to the atTiny45 chip at 8 mHZ
then I try to upload the software serial code with the aTtiny45(8mHz internal clock) board selected still. it doesn't work when i try to choose the aTtiny45 with arduino as isp. i have a 10uF cap on the board between reset and ground after uploading the isp
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0, 1); // RX, TX
// set the data rate for the SoftwareSerial port
mySerial.begin(4800);
mySerial.println("Hello, world?");
pinMode(0, INPUT);
pinMode(1, OUTPUT);
pinMode(3, INPUT_PULLUP);
void loop() // run over and over
int sensorValue = analogRead(3);
mySerial.println(sensorValue);
i get the following error, which is normal:
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny45
but nothing in the serial monitor, except for this when i try different baudrates: ÿÿÿÿÿÿÿÿÿ
does any one have code that they know works? and/or am i doing something out of order? i've tried all the different pin connections, uploading order etc
thanks!
That core is reported to not work with Software serial, install the latest from here; Google Code Archive - Long-term storage for Google Code Project Hosting.
This error
"avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny45"
Can be ignored, just forget it is there it does no harm.
thanks
i downloaded the new core you recommended, and i am still not seeing anything. does the code look alright? i tried the code from the funduino example as well, do i need to open the serial port somehow, and should i have the 45 (with 8MHz clock) board selected when uploading the serial sketch?
it says it burned bootloader successfully.
i know the error can be ignored but it is still not working.
I ran into a similar problem a while back while trying to use NewSoftSerial on my ATTiny85's... It worked fine for me on Arduino 1.0 after using the update hardware files, but I still prefer to use the AVRISP sketch from Arduino 0022. I didn't have to use a 10uf cap on my UNO, but you should have one just in case. Lastly, you don't need to define your serial pins as inputs/outputs, just start "mySerial" and it should all work. Let me know if you have any further problems
Cheers!
Mr_E :slight_smile:
How do you connect the tx pin on Attiny85 to your computer?
I have succesfully used a cheap CP2102 like this one and the updated core from
http://code.google.com/p/arduino-tiny/
CP2102
http://www.ebay.com/itm/CP2102-USB-2-0-to-UART-TTL-6PIN-Module-Serial-Converter-/130683943875?pt=LH_DefaultDomain_0&hash=item1e6d5ebbc3
The subject is discussede in this thread:
http://arduino.cc/forum/index.php/topic,109081.0.html
And finally, if you only need one way communication (from the tiny to your PC) you don't need a library, you can just use TinyDebugSerial
