Hi
This is my first time at trying to program anything.
I have the Arduino Duemilanove Board.
I am trying to get the board to switch on or off 8 relays.
I have modified some code I have found on the internet and I am able to switch the 8 relays on and off ok. But the problem I am having is the command is being repeated so the relay is constantly switching on and off.
What I want is for a pulse to switch the relay on for 1 second then switch the relay off and wait for the next command.
here is the code I am using.
char val; // variable to receive data from the serial port
int ledpin = 2; // LED connected to pin 2 to 9 (on-board LED)
pinMode(ledpin = 2, OUTPUT); // pin 2 (on-board LED) as OUTPUT
pinMode(ledpin = 3, OUTPUT); // pin 3 (on-board LED) as OUTPUT
pinMode(ledpin = 4, OUTPUT); // pin 4 (on-board LED) as OUTPUT
pinMode(ledpin = 5, OUTPUT); // pin 5 (on-board LED) as OUTPUT
pinMode(ledpin = 6, OUTPUT); // pin 6 (on-board LED) as OUTPUT
pinMode(ledpin = 7, OUTPUT); // pin 7 (on-board LED) as OUTPUT
pinMode(ledpin = 8, OUTPUT); // pin 8 (on-board LED) as OUTPUT
pinMode(ledpin = 9, OUTPUT); // pin 9 (on-board LED) as OUTPUT
Serial.begin(9600); // start serial communication at 9600bps
Serial.println("Press 1 - 9 to toggle relay on/off");
if( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in 'val'
if( val == '2' ) // if '2' was received
digitalWrite(ledpin = 2, HIGH); // turn ON the LED
delay(1000); // waits for a second
Serial.println("Relay 2 on");
digitalWrite(ledpin, LOW); // sets the LED off
if( val == '3' ) // if '3' was received
digitalWrite(ledpin = 3, HIGH); // turn ON the LED
Serial.println("Relay 3 on");
if( val == '4' ) // if '4' was received
digitalWrite(ledpin = 4, HIGH); // turn ON the LED
Serial.println("Relay 4 on");
if( val == '5' ) // if '5' was received
digitalWrite(ledpin = 5, HIGH); // turn ON the LED
Serial.println("Relay 5 on");
if( val == '6' ) // if '6' was received
digitalWrite(ledpin = 6, HIGH); // turn ON the LED
Serial.println("Relay 6 on");
if( val == '7' ) // if '7' was received
digitalWrite(ledpin = 7, HIGH); // turn ON the LED
Serial.println("Relay 7 on");
if( val == '8' ) // if '8' was received
digitalWrite(ledpin = 8, HIGH); // turn ON the LED
Serial.println("Relay 8 on");
if( val == '9' ) // if '9' was received
digitalWrite(ledpin = 9, HIGH); // turn ON the LED
Serial.println("Relay 9 on");
Please can someone tell me where I'm going wrong.
Simon
