Hi someone know a way to store and read negative numbers from EEProm than this?
I check if the number is less than 0
then i make a flag in position 0x08,
if 0x08 is=1 then the number is negative.
if 0x08 is=0 then the number is positive.
Then i multiply the number x (-1) this operation convert -65 to 65 and then i write the number in position 0x06 but with a flag in position 0x08 that indicates that CError is negative.
And for read, first i check the flag if is 1.
then i read the number that is stored in eeprom as positive & multiply the number again by (-1) that convert again in negative after read 0x06 position.
but this spend some memory, is not much but im sure that spend much more memory than some correct, official, or whatever the hell it's called.
signed int CError = -65;
//===========write to EEprom negative number
if (CError < 0){
CError=CError * (-1);
EEPROM.write(0x08,0x01);
delay(50);
else EEPROM.write(0x08,0x00);
EEPROM.write(0x06, CError);
//===========Read from EEProm negative number
if (EEPROM.read(0x08)==1){
delay(50);
CError=EEPROM.read(0x06)*(-1);
else CError=EEPROM.read(0x06);
Use a signed int as the data type for the variable and then save it using EEPROM.put()
Load it back to a signed int variable using EEPROM.get()
Note that it takes 2 bytes of EEPROM to hold an int variable on most, but not all, Arduinos so that 2 ints cannot be saved in adjoining EEPROM addresses
I checked it but if i remember well, just work with negative number, when the number is positive is flaged as negative and i need to store a variable from -100 to 100
Add 100 to the value before you EEPROM.write() it to ensure that it is positive then, when you EEPROM.read() it subtract 100 to get back the original value
For example :
The value is -100
Add 100 and you get 0
Save the value of 0
Read back the value and get 0
Subtract 100 and you get -100, which is the original value
