Hood day
I hope someone can point me in the right direction.
I need to store ir codes onto a sd card and be able to read a specific code from the card when needed.
I want to uses 2 methods to store the data.
1 = learn the row code and store it and replay it when necessary.(works on epromm but are to small for the amount of codes
needed.
2 = I also need to store LIRC codes (these can be in a separate file) and recall them when i need it.
I know there are diffident methods to store data to sdcard.
But my thinking is to store the codes an a indexed text or cvs file- call the index to get ir code.This way you can change and update the LIRC data from a pc.
something like
1 321321312 tv on
2 343242343 tv off
3 343254355 av 1
Is there a way to do this?
I know there might be a second option by storing data directly to the sdcard with raw data(I will also consider this method)
I believe the extended database library should work here, but don't know if it will work for this application.Can't find any examples where the sdcard are used.
I am just looking for guidance and if it is possible to store the data in this way, could not find conclusive information on Google
Or other suggestions that will have a similar outcome.
I am still new to Arduino and programing so any assistance would be appreciated.
