I'm working on a robot arm with multiple servos on an Adafruit PWM Servo Driver. I have code so I can adjust each of their positions using a potentiometer. Then I note the position of a servo, move to the next one, adjust it, note its position, etc. This allows me to set the arm into a position, tweaking each servo until all of them are just right. The position of each servo is shown on an OLED screen. The servo positions can be used in a function to get the robot to move into a specific position.
What I have now uses the following:
Arduino
Adafruit PWM Servo driver
Potentiometer
Buttons
OLED screen
Potentiometer + Adafruit PWM Servo Driver + OLED + Buttons
Adafruit PWM & pot:
https://forums.adafruit.com/viewtopic.php?f=31&t=119704
Connections:
Adafruit PWM to 5V, GND, SDA and SCL pins
OLED to 5V, GND, SDA and SCL pins
Potentiometer to A0
11/9/21: Changed from LCD to OLED using U8g2 library.
Works great! Picked best font for clarity.
11/9/21: Added JCButton library to manage switching servos
#include <Wire.h>
// JC Button library
#include <JC_Button.h>
// JC Button pin assignments
const byte
DN_PIN(7),
UP_PIN(8); // connect a button from these pins to ground
Button btnUP(UP_PIN), btnDN(DN_PIN); // define the buttons
const unsigned long
REPEAT_FIRST(500), // ms required before repeating on long press
REPEAT_INCR(100); // repeat interval for long press
const int
MIN_COUNT(0),
MAX_COUNT(16);
// OLED - U8g2 library
#include <Arduino.h>
#include <U8x8lib.h>
U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
// Adafruit PWM
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN 150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // this is the 'maximum' pulse length count (out of 4096)
// pot constants
const int potPin1 = A0; //potentiometer pin
// variables
int val;
int pulseLength;
btnUP.begin();
btnDN.begin();
u8x8.begin();
u8x8.setPowerSave(0);
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
yield();
static int
count, // the number that is adjusted
lastCount(-1); // previous value of count (initialized to ensure it's different when the sketch starts)
static unsigned long
rpt(REPEAT_FIRST); // a variable time that is used to drive the repeats for long presses
enum states_t {WAIT, INCR, DECR}; // states for the state machine
static states_t STATE; // current state machine state
btnUP.read(); // read the buttons
btnDN.read();
if (count != lastCount) // print the count if it has changed
lastCount = count;
Serial.println(count, DEC);
switch (STATE)
case WAIT: // wait for a button event
if (btnUP.wasPressed())
STATE = INCR;
else if (btnDN.wasPressed())
STATE = DECR;
else if (btnUP.wasReleased()) // reset the long press interval
rpt = REPEAT_FIRST;
else if (btnDN.wasReleased())
rpt = REPEAT_FIRST;
else if (btnUP.pressedFor(rpt)) // check for long press
rpt += REPEAT_INCR; // increment the long press interval
STATE = INCR;
else if (btnDN.pressedFor(rpt))
rpt += REPEAT_INCR;
STATE = DECR;
val = analogRead(potPin1); // reads the value of the potentiometer (value between 0 and 1023)
pulseLength = map(val, 0, 1023, SERVOMIN, SERVOMAX); //map potentiometer to SERVOMIN and SERVOMAX
pwm.setPWM(count, 0, pulseLength);
//u8x8.setFont(u8x8_font_courB18_2x3_f); // This is good, fits single-digit servo
u8x8.setFont(u8x8_font_inr21_2x4_f); // Good one!
// Display selected servo
u8x8.setCursor(0, 0);
u8x8.print("Servo:");
if (count < 10) {
u8x8.setCursor(14, 0);
u8x8.print(" "); // Need this to get rid of flickering & stray pixels from numbers over 10
u8x8.setCursor(12, 0);
u8x8.print(count);
else {
u8x8.print(count);
// Display Pulse Length of servo position
u8x8.setCursor(0, 4);
u8x8.print("Pul:");
u8x8.setCursor(8, 4);
u8x8.print(pulseLength);
case INCR:
++count; // increment the counter
count = min(count, MAX_COUNT); // but not more than the specified maximum
STATE = WAIT;
case DECR:
--count; // decrement the counter
count = max(count, MIN_COUNT); // but not less than the specified minimum
STATE = WAIT;
This works fine so far, but the problem is that the servo positions aren't stored. Let's say I move the robot shoulder to a position, then press the button to move to the elbow servo. I adjust that, then realize that the shoulder should be a little different. I press a button to go back to the shoulder servo, but the position of the pot for the elbow is read and the shoulder moves to that angle.
I would like to be able to toggle through all servos, setting their angles, without having to write down the current angle of servo before moving to the next. Then at the end I should be able to toggle through the servos, and see their angles and record them.
Also the idea is to have this as a free-standing board that doesn't need to be connected to a PC to work, that's why I'm using the OLED.
What's the best approach? I have a couple of rotary encoders available. I can see incrementing/decrementing the servo angles that way. Or should I continue with the pot and add an array, adding an extra button to change or store the value?
