Storing this code to EEPROM (SHARP IR SENSOR)
Hello everyone,
I'm really new to this microcontroller.
I'm using a sharp IR sensor GP2Y0A21 and I already have the code (credits to the one who made it, totally forgot) but I cant figure out how to put this code on a EEPROMwrite/read sketch.
I'm using it as stage level and i'ts giving me accurate-ish distance but it seems i dont know how to store it to EEPROM.
Can someone please help me how to put this code to an EEPROMwrite/read sketch??
int IRpin = 1;                                    // analog pin for reading the IR sensor
  Serial.begin(9600);                             // start the serial port
  float volts = analogRead(IRpin)*0.0048828125;   // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
  float distance = 27*pow(volts, -1.10);          // worked out from graph 27 = theretical distance / (1/Volts)S - luckylarry.co.uk
  Serial.println(distance);                       // print the distance
  delay(1000);                                     // arbitary wait time.
Thanks.
Cheers.
What do you want to write to EEPROM? Why?
