Strange Arduino Board Situation
Hello, recently I have been trying to make an automatic plant water that uses an automatic siphon to put water into this big tube with holes to water 8 plants. (How Siphons work: https://www.youtube.com/watch?v=1vq_h4myH1E&ab_channel=D%21NG) However, when I tried making some simple code to make two server motors and then uploading the code into the Arduino with the right setup (it is not two in the code) it just basically ignores everything else and then the serial monitor only says "IR Receiver Button Decode". I tried everything to check if I had a random library in the code, testing the serial, and pressing the RESET button on my board but it kept saying "IR Receiver Button Decode". So I go here hoping that someone can solve this. (If you need any other information let me know)
#include <Servo.h>
Servo servo; // CServo object
const int servoPin = 9;
  servo.attach(servoPin);
  Serial.println("test - starting fresh");
  Serial.println("Testing serial output...");
  delay(50000);
  servo.write(0);
  delay(50000);
  servo.write(180);
  delay(50000);
Thanks,
Stickfigre
Well I tried your code and it does exactly what it should do. It prints
Followed by a 0.6mS pulse
Followed by a 2.44ms pulse.
As the delays in the loop function are 50 seconds each then the whole cycle repeats in 50 * 3 = 150 seconds.
Now this is a stupidly long time, so use a delay value of 3 seconds
delay(3000);
Also add a small delay in the setup function so it reads
  delay(300); // give time for serial port to start
It looks like you are not actual running the code you think you are.
Well, then what can make me run a different code?
Select the correct board from the menu Tools -> board. If you do not see it then download a driver from Tools -> board. -> board manager. Then load up a known good program like blink, found at the menu Files -> Examples -> 01 Basic -> blink.
Then download it to your board. I used IDE 1.8.19, Check the port matches your board Tools -> port and it will run.
Then go to your code again, make the changes I suggested so the servo movement happens faster than every two and a half minutes.
Ok thanks I will try it as soon as possible. (Also I alr made the time adjustments to the code to one second).
Hey, I just tried your method but a strange message came up when I tried it:
I also tried it again but then a different message popped up:
. And I did make sure to make the port go to the same board but it still won't work.
Can you please not post screen shots. They are too low a resolution to see correctly and they waste a lot of space, copy them and post them just like you would post code.
Thanks
Did you read any of the links associated with the error messages?
Yeah sorry for the screenshot I will do what you said. I did check out the link but it only solved an issue for Mac and I only use Windows and the cloud editor, also there were more links but they all led nowhere. However, I did turn something on that one about "verbose output during" and I turned on both the compilation and upload here is what I got (hopefully it is useful (also it is in the right port I checked)) :
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Steven\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Steven\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Steven\Documents\Arduino\libraries -fqbn=arduino:avr:yun -vid-pid=2341_0042 -ide-version=10819 -build-path C:\Users\Steven\AppData\Local\Temp\arduino_build_405399 -warnings=none -build-cache C:\Users\Steven\AppData\Local\Temp\arduino_cache_465040 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\Steven\Documents\Arduino\AquaBionic_Code\AquaBionic_Code.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Steven\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Steven\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Steven\Documents\Arduino\libraries -fqbn=arduino:avr:yun -vid-pid=2341_0042 -ide-version=10819 -build-path C:\Users\Steven\AppData\Local\Temp\arduino_build_405399 -warnings=none -build-cache C:\Users\Steven\AppData\Local\Temp\arduino_cache_465040 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\Steven\Documents\Arduino\AquaBionic_Code\AquaBionic_Code.ino
Using board 'yun' from platform in folder: C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\sketch\\AquaBionic_Code.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\sketch\\AquaBionic_Code.ino.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\sketch\\AquaBionic_Code.ino.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\sketch\\AquaBionic_Code.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_pulse.S.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\WInterrupts.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_analog.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\hooks.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\hooks.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_digital.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_pulse.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_shift.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\CDC.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\IPAddress.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\PluggableUSB.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Print.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\Print.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\Stream.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\Tone.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\USBCore.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\WMath.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WString.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\WString.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\abi.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\abi.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\main.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\main.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino Yun\"" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\yun" "C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\new.cpp" -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\new.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_pulse.S.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\WInterrupts.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\hooks.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_analog.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_digital.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_pulse.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\wiring_shift.c.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\CDC.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\IPAddress.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\PluggableUSB.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\Print.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\Stream.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\Tone.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\USBCore.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\WMath.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\WString.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\abi.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\main.cpp.o"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\core.a" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\Steven\AppData\Local\Temp\arduino_cache_465040\core\core_arduino_avr_yun_1c81ce78589c670aeef1293de434dd4b.a
Linking everything together...
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/AquaBionic_Code.ino.elf" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399\\sketch\\AquaBionic_Code.ino.cpp.o" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/core\\core.a" "-LC:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399" -lm
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/AquaBionic_Code.ino.elf" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/AquaBionic_Code.ino.eep"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/AquaBionic_Code.ino.elf" "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/AquaBionic_Code.ino.hex"
"C:\\Users\\Steven\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Steven\\AppData\\Local\\Temp\\arduino_build_405399/AquaBionic_Code.ino.elf"
Sketch uses 5516 bytes (19%) of program storage space. Maximum is 28672 bytes.
Global variables use 325 bytes (12%) of dynamic memory, leaving 2235 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM3
PORTS {COM3, } / {COM3, } => {}
Uploading using selected port: COM3
C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM3 -b57600 -D -Uflash:w:C:\Users\Steven\AppData\Local\Temp\arduino_build_405399/AquaBionic_Code.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Steven\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ")�"; type = �
    Software Version = �.
The error looks like your cable is not a data cable... only supplying power to the Arduino USB connector. Remove and re-insert the USB cable and listen for a system device insertion tone. Describe the results.
Ok just tried it, when I first disconnected the Arduino from the USB the computer made a low dun dun sound but then when I connected it back it made a high dun dun. I tried only the usb itself but it made no sound. (Edit also I use this type of data wire: Amazon.com: DIYables USB Cable for Arduino Uno Mega, USB 2.0 Cable Type A/B, 2 Pieces : Electronics)
Cable is probably good.
Do you know if the USB chip is FTDI or CH340? Look in DEVICE MANAGER >> LPT & PORTS or watch DEVMAN scan for new devices.
I got a COM 3??: (sorry gumpy_mike had to show him (don't be grumpy with me :slight_smile: ))
Are you using this board?
I am not sure how to check but I got this board from this kit: EL-KIT-008-Project-Complete-Ultimate-TUTORIAL
The IC will be in the area of the USB port.
If you have a Mega 2560 in the kit, select that as the board in the ide selection under Tools.
Did you select "Yun" as the board or is there some sort of gremlin in your system.
I chose that just because it is just a random board I selected I couldn't find the exact model of the board
I couldn't tell which numbers were the IC so I took photos of all of them (might need to zoom in closely.
Pictures are too small. Try to read them... looking for FTDI or CH340. Look near the USB port.
If you navigate in the IDE
Tools>Board>Ardino AVR Boards>Arduino Mega or Mega 2560
