Hi, i have a function that has no return value and can take either a boolean or int value:
void f(boolean p);
void f(int p);
so i expect to call the appropriate function when i pass the boolean or int parameter, yet when i pass the function "true":
f(true);
the f(int p) is called instead of f(boolean t)
i can correct it by calling the function with:
f((boolean)true);
but i think it's ugly, and wrong
Any solution to that problem? Is it a problem at all, or is it expected behavior?
The symbol true is #defined into existence. It has a numeric value associated with it. So, true is an int, as is false.
You could do something like this:
boolean stat = true;
f(stat);
umm... is boolean then a byte long or is it shorter(longer)?
if it isn't really a single bit, what's the point of having it?
in wiring.h:
#define true 0x1
#define false 0x0
so it really doesn't have a length per se.
ok, i found in reference answer to my question, boolean is one byte long, so i can just use one function that takes a byte, or use your approach with a variable
tnx for quick answers
If you've got a boolean, why not have a function that takes a boolean, and not a byte?
This code works, I think; I'm out of town without an arduino to run it on, but the disassembly looks like it does the intended thing. I couldn't get #undef to work.
//#undef true Â
//#undef false
const boolean True = 1;
const boolean False = 0;
void f(int x) {
 Serial.print("integer version");
void f(boolean x) {
 Serial.print("boolean version");
void setup(void){
void loop (void){
 f(True);//boolean
 //comment line
 f(1);//integer
I, for one, think the definition of true and false should be changed.
