Hi all,
I have an ESP32 Wroom and when i try to plug a thumb throttle on pin 13 and a push button on pin 27 everithing work fine i succeed to read the hall value but when i press the button the signal of the hall is incorrect it pass to full (10 bit => 4095).
Do you have an explanation on what wrong with my code or my electrical schema? I tried to change the input mode as well but not working also. Every answer is appreciated.
pinMode(27, INPUT);
LectureEntree();
void LectureEntree()
int sensorValue = 0;
int i=0;
for (i=0;i<=20;i++){
sensorValue = sensorValue + analogRead(13);
throttleIn =(int)(sensorValue/20);
Serial.print("Signal of the hall: ");
Serial.println(throttleIn);
20 * 4096 is too much to fit into an int. It will rollover.
0 to <=20 is 21 readings.
Leo..
unsigned int sensorValue = 0;
for (int i = 0; i < 20; i++) sensorValue += analogRead(13);
throttleIn = sensorValue / 20;
