I try to fill a ledstrip of 60 leds with 1 color and change the brightness
I do it this way
1.
int t = map(Spectrum[0],0,1024,0,255);
fill_solid(leds,NUM_LEDS,CHSV(255,255,t));
FastLED.delay(2);
2.
fill_solid(leds,NUM_LEDS,RED);
FastLED.setBrightness(t);
FastLED.delay(2);
but by doing this, both ways, it only doesn't change the brightness, but also the colors. It is not only red, but also blue, ...
when I try
for (int u=0;u>255;u++){
FastLED.setBrightness(u);
FastLED.delay(2);
it changes the brightness and leave the color to red.
Why isn't it working the first way?
I really can't find the solution
Resha:
I do it this way
1.
FastLED.delay(2);
It's because 'pure red' in the HSV color system is 0 and not 255. The color number 255 is mostly red with a small amount of blue in it. In lower brightness only pure red appears, in higher brigthness a small amout of 1, 2 or 3 blue will be mixed into.
For a pure red only you'd better try:
fill_solid(leds,NUM_LEDS,CHSV(0,255,t));
FastLED.delay(2);
Or use RGB color system instead of HSV color system, if you want control the pure R, G and B colors.
