Strange issue with interrupts (quadrature encoder)
I have a Pololu 4x encoder and am trying to write some code to make it work on my Nano 33 BLE. (Interestingly enough, the issue preventing some pre-existing libraries from working for me is the same issue that I'm about to describe here...)
When I turn the motor shaft clockwise, these are the signals that I get (first bit in each line is channel A, second bit channel B):
11 -> 10 -> 11 -> 10 -> 11 -> 10
Note how channel A's value never changes, and B's value toggles back and forth.
Likewise, for the counterclockwise direction:
01 -> 11 -> 01 -> 11 -> 01 -> 11
This is of course wrong, as the channels' values should be something like 00 -> 10 -> 11 -> 01 -> 00 as the shaft turns. As a matter of fact, that is exactly what I get when I run the exact same code on a regular Arduino Nano.
Does anyone know what's going on? Here's my code. AFAIK I'm not using interrupts incorrectly or anything, at least on the regular Nano.
#define PIN_A 2
#define PIN_B 3
volatile int val = 0;
volatile bool newVal = true;
void encoder() {
  int a = digitalRead(PIN_A);
  int b = digitalRead(PIN_B);
  val = ((a << 1) | b);
  newVal = true;
  Serial.begin(57600);
  pinMode(PIN_A, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(PIN_A), encoder, CHANGE);
  pinMode(PIN_B, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(PIN_B), encoder, CHANGE);
  if (newVal) {
    Serial.print(bool(val & 0b10));
    Serial.print(bool(val & 0b01));
    newVal = false;
After taking a look at the following diagram, it appears that the erroneous encoder patterns match those in which only rising edges are detected. So for some reason, attachInterrupt() is acting as if the CHANGE argument were RISING instead for the Nano BLE. Not sure why this is the case though.
The cause of the issue was that attachInterrupt()'s implementation in the nRF528x Mbed core does not properly support rising/falling edge detection as required for mode CHANGE. I've opened a pull request implementing the changes required and tested them with my encoder, and I can confirm that everything works properly now.
