Hi I'm doing something wrong here i have a basic midi foot controller which has 10 buttons
4 program change buttons
4 cc buttons
2 bank buttons
I recently added a double function to the bank up button when it is in run mode it works as a bank switch
when it is pressed for a long time it lets you go into an edit function.
but when I press the bank up button it makes the midi go mad and sends out 6 or 7 messages
that haven't been programmed... even with no midi code added to the bank button.
I have tried changing the button. also put in a different long code for the button but it does the same thing.
also tried the midi Library instead of sending serial midi.
when I put the bank up button into a normal state change code it works fine so i don't think it's a hardware problem.
The sketch is a bit long but I` will include it. anyway, any help with this would be great.
Tia.
//#include <LiquidCrystal.h>
#include <EEPROM.h>
//#include <LCD.h>
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
int Cc1add = 99;
int Cc2add = 102;
int Cc3add = 109;
int Cc4add = 106;
bool CCmode;
bool Loopmode;
unsigned long currentMillis;
const int AAbutton[] = { 15, 16, A0};
const int numButtons = sizeof(AAbutton) / sizeof(AAbutton[0]);
enum { AA_2, AA_3, AA_4};
boolean ledState = false;
boolean AledState = false;
int lastButtonState[numButtons];
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
//# define POSITIVE 1
LiquidCrystal_I2C lcd (0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int buttonStatePrevious = HIGH; // previousstate of the switch
unsigned long Duration = 100;
unsigned long minButtonLongPressDuration = 300;
unsigned long LDuration = 500;// Time we wait before we see the press as a long press
unsigned long buttonLongPressMillis; // Time in ms when we the button was pressed
bool buttonStateLongPress = false; // True if it is a long press
int counter = 0;
const int intervalButton = 50; // Time between two readings of the button state
unsigned long previousButtonMillis; // Timestamp of the latest reading
//bool buttonStateLongPress2 = false;
unsigned long buttonPressDuration;
int SWITCH1 = 4;
int SWITCH2 = 5;
int SWITCH3 = 6;
int SWITCH4 = 7;
int CCbutold = 1;
boolean flashing = false;
boolean flashingd = false;
//byte currentButtonState = HIGH;
//byte previousButtonState = HIGH;
unsigned long currentTime;
unsigned long onoffStarted;
long flashPeriod = 500;
bool lcdstate = true;
bool toggle = false;
int count = 0;
int previousBankdState = HIGH;
int currentBankdState = HIGH;
int Bankup;
int Bankdown;
int upLastTime = 0;
int downLastTime;
int upNow = 0;
int downNow;
int coun = 0;
int cc1c = 0;
int Con3 = 0;
byte glyphs[5][8] = {
{ B11111, B11111, B00000, B00000, B00000, B00000, B00000, B00000 } ,
{ B00000, B00000, B00000, B00000, B00000, B00000, B11111, B11111 } ,
{ B11111, B11111, B00000, B00000, B00000, B00000, B11111, B11111 } ,
{ B11111, B11111, B11111, B11111, B11111, B11111, B11111, B11111 } ,
{ B00000, B00000, B00000, B00000, B00000, B01110, B01110, B01110 }
const int digitWidth = 3; // the width in characters of a big digit (excludes space between characters)
//arrays to index into custom characters that will comprise the big numbers
// digits 0 - 4 0 1 2 3 4
const char bigDigitsTop[10][digitWidth] = { 3, 0, 3, 0, 3, 32, 2, 2, 3, 0, 2, 3, 3, 1, 3,
// digits 5-9 5 6 7 8 9
3, 2, 2, 3, 2, 2, 0, 0, 3, 3, 2, 3, 3, 2, 3
const char bigDigitsBot[10][ digitWidth] = { 3, 1, 3, 1, 3, 1, 3, 1, 1, 1, 1, 3, 32, 32, 3,
1, 1, 3, 3, 1, 3, 32, 32, 3, 3, 1, 3, 1, 1, 3
char buffer[12]; // used to convert a number into a string
#define BOUNCEDELAY 25
// Variables:
int switches[4] = { SWITCH1, SWITCH2, SWITCH3, SWITCH4,};
int switchState[4] = { HIGH, HIGH, HIGH, HIGH,};
// Initial state of switch is high due to internal pullup
//int leds[4] = { 7, 8, 9, 10};
int currentSwitch = 0;
int currentProgram = 0; // current program - sent to the output
int progNo = 0;
//int upLastTime, downLastTime;
int prog;
int progdown;
int bankminus = 0;
int bank = 0;
int bankup = 0;
int detectswitch;
int leadled = 12;
int menu = 0;
boolean ledon = false;
boolean editmode = false;
//const int lead = 12;
const int L1 = 8;
const int L2 = 9;
const int L3 = 10;
const int L4 = 11;
const int AA2 = 22;
const int AA3 = 23;
const int AA1 = 24;
const int bankPin = 2;
int disp;
int dispc;
const int bankdpin = 3;
int CC1 = 14;
int Con2 = 0;
int CCC3 = 0;
int CCC4 = 0;
boolean ledVal1 = false; // state of LED 1
boolean ledVal2 = false; // state of LED 2
boolean ledVal3 = false; // state of LED 3
boolean ledVal4 = false; // state of LED 4
// Set MIDI baud rate:
//Serial.begin(31250);
//Serial.begin(9600);
MIDI.begin();
lcd.begin(16, 2);
for ( int i = 0; i < numButtons; ++i ) {
pinMode (AAbutton[i], INPUT_PULLUP);
pinMode(CC1, INPUT_PULLUP);
pinMode(SWITCH1, INPUT_PULLUP);
pinMode(SWITCH2, INPUT_PULLUP);
pinMode(SWITCH3, INPUT_PULLUP);
pinMode(SWITCH4, INPUT_PULLUP);
// lcd.print(currentSwitch);
lcd.setCursor(3, 0); // top left
lcd.print("ENIGMA rev2");
lcd.setCursor(3, 2);
lcd.print("Press Button");
// lcd.clear();
// create the custom glyphs
for (int i = 0; i < 5; i++)
lcd.createChar(i, glyphs[i]); // create the 5 custom glyphs
//digitalWrite(14, HIGH);
pinMode(L1, OUTPUT);
pinMode(L2, OUTPUT);
pinMode(L3, OUTPUT);
pinMode(L4, OUTPUT);
pinMode(leadled, OUTPUT);
pinMode(AA2, OUTPUT);
pinMode(AA3, OUTPUT);
pinMode(AA1, OUTPUT);
pinMode(bankPin, INPUT_PULLUP);
pinMode(bankdpin, INPUT_PULLUP);
int b = checkButton();
if (b == 1) clickEvent();
if (b == 2) doubleClickEvent();
if (b == 3) holdEvent();
if (b == 4) longHoldEvent();
// readButtonState(); // read the button state
// int buttonState;
/* buttonState = digitalRead(AAbutton[AA_2]);
// compare the buttonState to its previous state
if (buttonState != lastButtonState[AA_2]) {
if (buttonState == LOW) {
// CCmode = false;
ledState = !ledState;
digitalWrite(AA2, ledState);
if(CCmode){
Con2++;
flashing = false; lcd.clear();
lcd.display();
lcd.setCursor(2, 5);
lcd.print("CC2 ");
lcd.print(Con2);
else if (ledState) {
EEPROM.get(Cc2add, Con2);
sendControlChange(Con2, 127);
}else {
sendControlChange(Con2, 0);
lastButtonState[AA_2] = buttonState;
int buttonState3 = digitalRead(AAbutton[AA_3]);
if (buttonState3 != lastButtonState[AA_3]) {
if (buttonState3 == LOW) {
// CCmode = false;
digitalWrite(AA3, ledState);
if(CCmode){
flashing = false;
//lcd.clear();
lcd.display();
Con3++;
lcd.print("CC3 ");
lcd.print(Con3);
EEPROM.get(Cc3add, Con3);
Serial.println(Con3);
sendControlChange(Con3, 127);
sendControlChange(Con3, 0);
lastButtonState[AA_3] = buttonState3;
buttonState = digitalRead(AAbutton[AA_4]);
if (buttonState != lastButtonState[AA_4]) {
digitalWrite(leadled, ledState);
if(CCmode){
CCC4++;
flashing = false;
//lcd.clear();
lcd.display();
lcd.print("CC4 ");
lcd.print(CCC4);
}else
if (ledState) {
EEPROM.get(Cc4add, CCC4);
sendControlChange(CCC4, 127);
sendControlChange(CCC4, 0);
lastButtonState[AA_4] = buttonState;*/
for ( currentSwitch = 0; currentSwitch < 4; currentSwitch++ ) {
if ((digitalRead(switches[currentSwitch]) != switchState[currentSwitch] ) && (switchState[currentSwitch] == LOW)) {
MIDI.sendProgramChange(currentSwitch + bank, 1);
// midiProg( 0xC0, currentSwitch + bank );
// onoffStarted = currentTime;
lcd.display();
coun = 0;
Con2 = 0;
Con3 = 0;
CCC4 = 0;
cc1c = 0;
flashing = false;
ledState = false;
//flashingd = false;
// digitalWrite(leadled,LOW);
lcd.clear();
// lcd.setCursor(0,0);
progdisplay();
disp = currentSwitch;
switch (disp) {
case 0 :
// lcd.setCursor(5,0);
// lcd.print("Clean");
//lcd.setCursor(0, 0);
//digitalWrite(L1,HIGH);
showNumber( disp + 1 + bank , 0);
case 1:
// lcd.clear();
// lcd.setCursor(10,0);
// lcd.print("Crunch");
// lcd.setCursor(0, 0);
showNumber( disp + 1 + bank, 0);
// digitalWrite(L2,HIGH);
case 2:
// lcd.clear();
// lcd.print("Lead");
case 3:
// lcd.clear();
// lcd.print("Drive");
showNumber(disp + 1 + bank, 0);
//**********************************************************displayNames*************************************
int switche;
//for (dispc = 0; dispc<6; dispc++){
digitalWrite(L1, (currentSwitch) == 0);
digitalWrite(L2, (currentSwitch) == 1);
digitalWrite(L3, (currentSwitch) == 2);
digitalWrite(L4, (currentSwitch) == 3);
delay( BOUNCEDELAY );
digitalWrite(leadled, LOW);
//showNumber( currentSwitch+1 + bank,0);
switchState[currentSwitch] = digitalRead( switches[currentSwitch] );
//***************************************Flashbankup**********************************************************
/* currentButtonState = digitalRead(bankPin);
if (currentButtonState != previousButtonState && currentButtonState == LOW) //button has become pressed
bank += 4;
if (bank > 16) bank = 0;
lcd.clear();
lcd.setCursor(9, 0);
lcd.print("Bankup");
//showNumber(7,0);
// lcd.print(count+=4);
flashing = true;
//digitalWrite(ledPin,HIGH);
previousButtonState = currentButtonState; //save the button state for the next check
if (flashing) {
Flashlcd();
// else
// showNumber(disp+1 + bank,0); //force the LED off if not flashing
// lcd.print(count++);
//***************************Bankdown*************************************************************************
currentBankdState = digitalRead(bankdpin);
if (currentBankdState != previousBankdState && currentBankdState == LOW) //button has become pressed
bank -= 4;
if (bank < 0) bank = 0;
lcd.clear();
lcd.print("Bankdn");
//showNumber(7,0);
flashing = true;
//digitalWrite(leadled,HIGH);
previousBankdState = currentBankdState; //save the button state for the next check
//CC Button 1
int CCbut = digitalRead(CC1);
if (CCbutold == 0 && CCbut == 1) {
if (CCmode) {
cc1c++;
flashing = false;
lcd.clear();
lcd.display();
lcd.print("CC1 ");
lcd.print(cc1c);
Serial.print(cc1c);
} else if (coun == 0) {
digitalWrite(leadled, HIGH);
EEPROM.get(Cc1add, cc1c);
//sendControlChange(cc1c, 127);
// MIDI.sendControlChange(90,127,1);
Serial.print(cc1c);
coun = 1;
//sendControlChange(cc1c, 0);
coun = 0;
// coun = 0;
CCbutold = CCbut;
delay(20);
void showDigit(int digit, int position)
lcd.setCursor(position * (digitWidth + 1), 0);
for (int i = 0; i < digitWidth; i++)
lcd.print(bigDigitsTop[digit][i]);
lcd.setCursor(position * (digitWidth + 1), 1);
lcd.print(bigDigitsBot[digit][i]);
void showNumber(int value, int position)
int index; // index to the digit being printed, 0 is the leftmost digit
itoa(value, buffer, 10); // see Recipe 2.8 for more on using itoa
// dislay each digit in sequence
for (index = 0; index < 10; index++) // display up to ten digits
char c = buffer[index];
if ( c == 0) // check for null (not the same as '0')
return; // the end of string character is a null, see Chapter 2
c = c - 48; // convert ascii value to a numeric value (see Recipe 2.9)
showDigit(c, position + index);
// Send a three byte midi message
void midiSend(char status, char data1, char data2) {
Serial.write(status);
Serial.write(data1);
Serial.write(data2);
// Send a two byte midi message
void midiProg(char status, int data ) {
Serial.write(data);
void sendControlChange(byte Ctrl, byte Value) {
Serial.write(0xB0);
Serial.write(Ctrl);
Serial.write(Value);
void Flashlcd() {
currentTime = millis();
if (currentTime - onoffStarted > flashPeriod) //if the flash period ended ?
if (lcdstate == true) { //check to see state of backlight
lcdstate = false; //flip state of backlight
else if (lcdstate == false) {
lcdstate = true;
if ( lcdstate == true) { //the bool argument for backlight state (true/false)
lcd.display();
//lcd.print("1");//the statement that actualy changes the backlight state
else if ( lcdstate == false) {
lcd.noDisplay();
//lcd.setCursor(0,0);
} //flip the state of the LED
onoffStarted = currentTime; //save the time when it occured
void readButtonState() {
currentMillis = millis(); // store the current time
// If the difference in time between the previous reading is larger than intervalButton
if (currentMillis - previousButtonMillis > intervalButton) {
// Read the digital value of the button (LOW/HIGH)
int buttonStateL = digitalRead(AAbutton[AA_4]);
// If the button has been pushed AND
// If the button wasn't pressed before AND
// IF there was not already a measurement running to determine how long the button has been pressed
if (buttonStateL == LOW && buttonStatePrevious == HIGH && !buttonStateLongPress) {
buttonLongPressMillis = currentMillis;
buttonStatePrevious = LOW;
Serial.println("Button pressed");
// Calculate how long the button has been pressed
buttonPressDuration = currentMillis - buttonLongPressMillis;
// If the button is pressed AND
// If there is no measurement running to determine how long the button is pressed AND
// If the time the button has been pressed is larger or equal to the time needed for a long press
if (buttonStateL == LOW && !buttonStateLongPress && buttonPressDuration >= minButtonLongPressDuration) {
buttonStateLongPress = true;
/* editmode = !editmode;
// flashing = false;
lcd.clear();
lcd.setCursor (0, 0);
lcd.print("EDITMODE");
Serial.println("Button long pressed");
if (!editmode) {
EEPROM.put(Cc1add, cc1c);
EEPROM.put(Cc2add, Con2);
EEPROM.put(Cc3add, Con3);
EEPROM.put(Cc4add, CCC4);
CCmode = false;
Serial.println("save");
lcd.clear();
lcd.print("Save");
lcd.clear();
lcd.display();
flashing = true;
// If the button is released AND
// If the button was pressed before
if (buttonStateL == HIGH && buttonStatePrevious == LOW) {
Serial.println("Button released");
if (buttonPressDuration < minButtonLongPressDuration) {
Serial.println("Button pressed shortly");
// bank += 4;
// if (bank > 16) bank = 0;
// lcd.clear();
// showNumber(disp + 1 + bank, 0);
//lcd.setCursor(9, 0);
// lcd.print("Bankup");
//showNumber(7,0);
// flashing = true;
//delay(50);
// if (editmode) {
// lcd.display();
// menu++;
// Cmenu();
// lcd.clear();
//lcd.setCursor (0, 0);
//lcd.print(editmode);
// store the current timestamp in previousButtonMillis
previousButtonMillis = currentMillis;
void Cmenu() {
switch (menu) {
case 1:
lcd.clear();
lcd.print("Select CC ");
// Serial.println("Select CC");
CCmode = true;
Loopmode = false;
case 2:
lcd.clear();
lcd.print("Loops 1 - 4");
Serial.println("Loops 1-4");
Loopmode = true;
CCmode = false;
case 3:
lcd.clear();
lcd.print("Loops 4 -8");
Serial.println("LOOPS 4-8");
case 4:
lcd.clear();
lcd.print("Display");
Serial.println("Display");
case 5:
lcd.clear();
lcd.print("Triggers");
Serial.println("Triggers");
default:
menu = 0;
void progdisplay() {
dispc = currentSwitch + bank;
switch (dispc) {
case 0 :
lcd.clear();
lcd.setCursor(5, 0);
lcd.print("Clean");
// showNumber( disp+1 + bank ,0);
case 1:
lcd.clear();
// showNumber( disp+1 + bank,0);
case 2:
lcd.clear();
lcd.print("Lead");
//showNumber( disp+1 + bank,0);
case 3:
lcd.clear();
lcd.print("Drive");
//showNumber(disp+1 + bank,0);
case 4:
lcd.clear();
lcd.print("Country");
case 5:
lcd.clear();
lcd.print("Tube S");
default:
lcd.setCursor(10, 0);
lcd.print(" ");
void clickEvent() {
ledVal1 = !ledVal1;
// digitalWrite(ledPin1, ledVal1);
if (ledVal1) {
// bank++;
// sendControlChange(90, 127);
// Serial.println("buton");
MIDI.sendControlChange(90, 127, 1);
void doubleClickEvent() {
ledVal2 = !ledVal2;
// digitalWrite(ledPin2, ledVal2);
void holdEvent() {
ledVal3 = !ledVal3;
// digitalWrite(ledPin3, ledVal3);
void longHoldEvent() {
ledVal4 = !ledVal4;
// digitalWrite(ledPin4, ledVal4);
// MULTI-CLICK: One Button, Multiple Events
// Button timing variables
int debounce = 20; // ms debounce period to prevent flickering when pressing or releasing the button
int DCgap = 250; // max ms between clicks for a double click event
int holdTime = 1000; // ms hold period: how long to wait for press+hold event
int longHoldTime = 3000; // ms long hold period: how long to wait for press+hold event
// Button variables
boolean buttonVal = HIGH; // value read from button
boolean buttonLast = HIGH; // buffered value of the button's previous state
boolean DCwaiting = false; // whether we're waiting for a double click (down)
boolean DConUp = false; // whether to register a double click on next release, or whether to wait and click
boolean singleOK = true; // whether it's OK to do a single click
long downTime = -1; // time the button was pressed down
long upTime = -1; // time the button was released
boolean ignoreUp = false; // whether to ignore the button release because the click+hold was triggered
boolean waitForUp = false; // when held, whether to wait for the up event
boolean holdEventPast = false; // whether or not the hold event happened already
boolean longHoldEventPast = false;// whether or not the long hold event happened already
int checkButton() {
int event = 0;
buttonVal = digitalRead(bankPin);
// Button pressed down
if (buttonVal == LOW && buttonLast == HIGH && (millis() - upTime) > debounce)
// i have tryed putting sendControlChange(82, 0);
// sendControlChange(90, 0);
downTime = millis();
ignoreUp = false;
waitForUp = false;
singleOK = true;
if ((millis() - upTime) < DCgap && DConUp == false && DCwaiting == true) DConUp = true;
else DConUp = false;
DCwaiting = false;
// Button released
else if (buttonVal == HIGH && buttonLast == LOW && (millis() - downTime) > debounce)
if (not ignoreUp)
Serial.println("butoff");
upTime = millis();
if (DConUp == false) DCwaiting = true;
event = 2;
DConUp = false;
DCwaiting = false;
singleOK = false;
// Test for normal click event: DCgap expired
if ( buttonVal == HIGH && (millis() - upTime) >= DCgap && DCwaiting == true && DConUp == false && singleOK == true && event != 2)
event = 1;
DCwaiting = false;
// Test for hold
if (buttonVal == LOW && (millis() - downTime) >= holdTime) {
// Trigger "normal" hold
if (not holdEventPast)
event = 3;
waitForUp = true;
ignoreUp = true;
DConUp = false;
DCwaiting = false;
//downTime = millis();
holdEventPast = true;
// Trigger "long" hold
if ((millis() - downTime) >= longHoldTime)
if (not longHoldEventPast)
event = 4;
longHoldEventPast = true;
buttonLast = buttonVal;
return event;
here is the double function
lcd.clear();
if (!editmode) {
CCmode = false;
lcd.clear();
lcd.print("Save");
lcd.clear();
lcd.display();
flashing = true;
// bank += 4;
// lcd.clear();
//showNumber(7,0);
// flashing = true;
//delay(50);
// if (editmode) {
// lcd.display();
// menu++;
// Cmenu();
// lcd.clear();
