Strange voltage on input pins
Hello,
why i have voltage on input_pullup pin and nothing connected to that pin?
Why do you think it's not to be expected? What would you expect?
I would think that it would be expected. The pin is pulled high by the internal pullup so should read Vcc with a multimeter.
@morhuh
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
sterretje:
Yeah, but when i change it to INPUT and connect pull down resistor still have around 2 V. I think its not expected because digitalRead didnt work as expected.
What's the value of the pull-down resistor? A schematic (photo of pencil drawing is fine). Which pin are you testing on?
Please show the last loaded sketch; paste it between
** **[code]** **
and
** **[/code]** **
, the so-called code tags.
To be clear, you are concerned with the readings on pins that do not have inputs connected to them? Why?
