String.replace() issues, doesn't work
Hey there. Currently making a universal global buffer for my ESP32-S3
It utilizes both char and String, char to fully receive serial data, String to store it in a readable and simple form.
One thing before you rush to comments, I absolutely don't care how bad String is with memory, don't recommend me to use c-string, thank you very much.
Part of my code:
String serialbuffer = "";
ESP assigns core 1 and core 2 functions
--Nothing here--
void core1() {
void core2() {
int xprocess(String arg) {
  Serial.println("SBF: |" + serialbuffer + "|\nCompare: |" + arg + "|");
  int dat = serialbuffer.indexOf(arg);
  if (dat > -1) {
    Serial.println("Replacing");
    serialbuffer.replace(arg, "");
  return dat;
void xreceive() {
  char* serialbuffertemp = "";
  while (sysPort.available()) {
    if (serialbuffer.length() > 1023) {
      serialbuffer = "";
    strcat(serialbuffertemp, Serial.readString().c_str());
  serialbuffer.concat(String(serialbuffertemp));
  serialbuffer.trim();
xreceive - Receives available data from Serial, stores into global String buffer. Note if the global String buffer is 1024 bytes or more, it will be emptied.
xprocess - Uses the provided String parameter and checks if it exists within the main buffer, if so, removes that part of text.
I tried using Serial.readString() directly, however with doing serialbuffer.concat(Serial.readString()), neither .indexOf, neither .replace worked...
Using this code, .indexOf works, however .replace doesn't.
ESP32 2.0.5 installed.
ESP32-S3-WROOM-1-N8 module used.
Help very much appreciated!
I think that in this case you yourself will solve your problem better than the forum
Can you show a small working sketch that shows the problem and that we can try ? thank you very much :clown_face:
I think that you have to write easy and simple code. Don't try to put a multitude of functionality into a single line.
Others might see other problems, but this code line got my attention at first glance, because it is over-complicated :
Looking at it better, I think that is a bug. You have reserved one byte in memory for the contents of 'serialbuffertemp', and then you write the received text to it.
This is a worse error than just a size. It is more important that this is not a text buffer, but a pointer to a literal. A literal is not meant to be modified, so the compiler may not allocate memory for it, but place a pointer to any other string with the same content.
For example, these two strings will actually share the same place in memory:
char* a = "ABCDE";
char* b = "CDE";
Since the line char* serialbuffertemp = ""; points to the string terminator char, which is in any other string in the program, than most likely the compiler will not allocate even 1 character for this line.
Bugs are never where you think they are (as pointed out by @Koepel ) :slight_smile:
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
No preaching here, but you can do a lot more, faster, in less memory with c-strings.
Mixing strings and Strings is a real deathwish for performance and reliability.
Choose one , and learn about it.
How about this part:
  ... Serial.readString()...
That is like saying "Who is there" when someone knocks on the neighbors door.
Thanks for the heads up about the categories!
Written as a precaution in case the secondary accessory connected via Serial is in progress of sending data while reading the buffer.
Got it, so I should allocate 1024 bytes to it for example.
So it should be char serialbuffertemp[1024] = "";?
I agree, however I couldn't find any proper methods to remove a word from a c-string.
Let me clarify, the plan is like this:
  • Get data from serial
  • Check if a word trigger exists in the buffer, if so, remove it from the buffer and continue to the requested function.
I have tried using String only, however as I mentioned in my original post, neither .replace() nor .indexOf() work when doing serialbuffer.concat(Serial.readString())
However both functions do work if I just do serialbuffer = Serial.readString()
Yeah it is over-complicated since as mentioned in my original post, and once more in post #11:
Neither .replace() nor .indexOf() work when doing serialbuffer.concat(Serial.readString())
As well as
Quick update:
Intializing the temporary char by doing char serialbuffertemp[1024] = "" fixed the .replace issue.
For those wondering why 1024, I have set the ESP serial buffer to 1024 bytes total in HardwareSerial.
That’s true, but there many online examples of short functions to insert, replace, or remove c-substrings.
Agreed, I made a mash up of those and it kind of worked but the whole code was so complicated and messy I just couldn't handle using it in my project, plus there were too many concerns about the stability.
