I have a serial stream I am reading in and extracting a value out that represents time in millisecond precision.
I need this converted back to a long in order to use in other parts of the program such as adjust my RTC if needed. Here is an example of what I am doing:
// Illustration of a function to convert a String
// to a long int using the C library function atol()
// (Arduino version 19 and successors)
// </begin Editorial>
// Why (oh why) didn't they just put something like the following
// in WString.h?
// const char * c_str() const {return _buffer;}
// Then the main program could have done something like the following
// long x = strtol(str.c_str(), NULL, 10);
// </end Editorial>
// davekw7x
String str("1423168911386");
Serial.print("The string : ");
Serial.println(str);
long x = stringToLong(str);
Serial.print("The long int : ");
Serial.println(x);
// I would have preferred the argument to be (const String & s)
// but that would be inconsistent with the lame definition of
// toCharArray in WString.h
// It also would have required the prototype to be in a separate
// header, since the Arduino prototype collector doesn't
// work with arguments that are references.
// Oh, well...
// davekw7x
unsigned long long stringToLong(String s)
char arr[12];
s.toCharArray(arr, sizeof(arr));
return atoll(arr);
I am expecting the string "1423168911386" to come back in as a number. Currently, I am getting this output:
The string : 1423168911386
The long int : 1346787225
How do I convert this string into all of the digits I need?
Presumably, it came from a 64 bit variable, so why not put it back into another?
(Note: the Arduino supports 64 bit artithmetic, but it's slow and serial I/O isn't well supported.)
sfyffe:
First of all you should avoid those 'String' objects that make your programs slow, RAM eating and incompatible to all the string functions in the AVR LIBC library!
Here is a solution for strings (char array, C-string, zero terminated string) instead of 'String' objects.
long long char2LL(char *str)
long long result = 0; // Initialize result
// Iterate through all characters of input string and update result
for (int i = 0; str[i] != '\0'; ++i)
result = result*10 + str[i] - '0';
return result;
void LL2Serial(long long ll)
uint64_t xx = ll/1000000000ULL;
if (xx >0) Serial.print((long)xx);
Serial.print((long)(ll-xx*1000000000));
char str[]="1423168911386";
long long x = char2LL(str);
Serial.print("The long long: ");
LL2Serial(x);
There is one function that converts a char array to 'long long' and there is another function that prints a 'long long' on Serial.
YOU CANNOT print 'long long' directly to Serial, as Serial does not support the 'long long' data type. So I made a little helper function, inspired from a robtillaart posting found in this forum.
If you want to use slow and RAM-eating 'String' objects instead: Do the changes you need for yourself - I don't want to support those freaking 'String' objects in any way.
P.S.: Which Arduino version supports a function "atoll(arr);"? Is that for Arduino DUE?
Not exactly sure what is on the DUO... This is for a custom board I created for the ESP8266 running an Atmel 644P..
Sometimes the string objest are just what we have to deal with especially using web services. Thanks for the code sample. I will work with it tomorrow and see what I can do.
