Strobe Light Effect, HELP PLS!
Can someone help me? I wanted to make a strobe light effect that rapidly blinks 30 milliseconds in every second, so the strobe light effect that rapidly blinks 30 milliseconds will turn on every second.
#include <Metro.h>
const int blinkPin1 = 7;
boolean blink1State = false;
Metro blink1Metro = Metro(1000);
Metro blink2Metro = Metro(30);
void setup(){
  pinMode(blinkPin1 , OUTPUT);
void loop(){
  if(blink1Metro.check()){
    if(blink2Metro.check()){
      blink1State = !blink1State;
      digitalWrite(blinkPin1, blink1State);
Please post a complete sketch using code tags as described in How to get the best out of this forum
What does the current code do ?
Done bro, edited already
Did you go back and update your code that you posted in post #1?
If so why, the aim of this forum is to help and give advise, this thread will now be useless in both ways.
If you had left your original code in post #1 and posted your fixed code in a new post, then the thread may have been useful to others.
Tom.... :smiley: :+1: :coffee: :australia:
The original code was so messy and too long, and I have the function that I wasn't able to solve it, so i took small part of it and shared it here, basically i took out the separate function of my whole code which i wasn't able to finish. anyways sorry for making confusions in this forum
The updated code has the same problem in my original code, i just took out the specific function from my original code and transferred it into another sketch, my apologies for confusion.
Can I suggest you forget about metro and look at the "blink without delay" example in the IDE.
It shows you how to simply blink a LED, you should be able to modify it.
Can you please tell us your electronics, programming, arduino, hardware experience?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Hello
post a timing diagramm to show the flash sequence.
This code may help.
  Blink without Delay
  Turns on and off a light emitting diode (LED) connected to a digital pin,
  without using the delay() function. This means that other code can run at the
  same time without being interrupted by the LED code.
  The circuit:
  - Use the onboard LED.
  - Note: Most Arduinos have an on-board LED you can control. On the UNO, MEGA
    and ZERO it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN
    is set to the correct LED pin independent of which board is used.
    If you want to know what pin the on-board LED is connected to on your
    Arduino model, check the Technical Specs of your board at:
    https://www.arduino.cc/en/Main/Products
  created 2005
  by David A. Mellis
  modified 8 Feb 2010
  by Paul Stoffregen
  modified 11 Nov 2013
  by Scott Fitzgerald
  modified 9 Jan 2017
  by Arturo Guadalupi
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to set a pin number:
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0;        // will store last time LED was updated
long interval = 0;         // interval at which to blink (milliseconds)
long ontime = 30; // ON time interval 30ms
long offtime = 970; // OFF time interval 970ms
  // set the digital pin as output:
  pinMode(blinkPin1, OUTPUT);
  interval = ontime;
  // check to see if it's time to blink the LED; that is, if the difference
  // between the current time and last time you blinked the LED is bigger than
  // the interval at which you want to blink the LED.
  if (currentMillis - previousMillis >= interval)
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      interval = ontime; //now that the LED will be ON, set the interval to ontime duration
      ledState = LOW;
      interval = offtime; //now that the LED will be OFF, set the interval to offtime duration
    // set the LED with the ledState of the variable:
    digitalWrite(blinkPin1, ledState);
It is an adaptation of the "Blink without delay" example.
I'm a new learner
Did it work?
Hello, thank you for your advise, I finally got what I wanted to happen, here's how I edited the code
  Blink without Delay
  The circuit:
  created 2005
  by David A. Mellis
  modified 8 Feb 2010
  by Paul Stoffregen
  by Scott Fitzgerald
  modified 9 Jan 2017
  by Arturo Guadalupi
long offtime = 30; // OFF time interval 970ms
long wraptime = 350;
int checker = 0;
  interval = ontime;
      ledState = HIGH;
      checker++;
      Serial.print(checker);
      checker++;
      ledState = LOW;
    if(checker == 20){
      ledState = LOW;
      interval = wraptime;
      checker = 0;
