Struct Question
I'm trying to incorporate structs into my code, but I'm getting a type error.
Basically, I'm trying to initialize a struct and all of its member variables outside of the setup() and loop() functions. Like this:
struct controlSurfaces
  byte command_index;
  byte rate_pin;
  uint16_t _offset;
  uint16_t high_rates_surface_max;
  uint16_t high_rates_surface_min;
  uint16_t low_rates_surface_max;
  uint16_t low_rates_surface_min;
  uint16_t ADC_max;
  uint16_t ADC_min;
}ailerons;
//setup aileron struct
ailerons.command_index          = 0;
ailerons.rate_pin               = 0;
ailerons.high_rates_surface_max = 0;
ailerons.high_rates_surface_min = 0;
ailerons.low_rates_surface_max  = 0;
ailerons.low_rates_surface_min  = 0;
ailerons.ADC_max                = 0;
ailerons.ADC_min                = 0;
  //do nothing
  //do nothing
But it gives me this error: 'ailerons' does not name a type
I did some research and I found that in C++ you can do the following:
struct Employee
    short id;
    int age;
    double wage;
Employee joe;
joe.id = 1;
joe.age = 32;
joe.wage = 60000.0;
Which, as far as I can tell, is exactly what I did in my sketch. What is going wrong?
needs to be inside a function.
Easier alternative
  byte command_index;
  byte rate_pin;
  uint16_t _offset;
  uint16_t ADC_max;
  uint16_t ADC_min;
controlSurfaces ailerons =
  0, 0, 0, 0, 0, 0, 0, 0, 0
Cool, thanks!
Put the initialization of ailerons in setup() and it will work.
