I'm (for the first time) to use a struct variable...
but I get every time a Does not name a type error?
this is what I have:
struct Corner {
int X;
int Y;
int Z;
Corner Corners[8];
Corners[0].X = 0;
struct Corner {
int X;
int Y;
int Z;
Corner Corners[8];
Corners[0].X = 0;
Hello
Try this to initialize the structured array:
struct Corner {
int X;
int Y;
int Z;
}Corners[] {
{0,0,0},
Post a complete code that that we can try in the Arduino IDE. Use Code Tags.
Can you post the full sketch? It could be a problem with where you are declaring the struct.
That's an assignment statement. It must be within a function.
Compiles without error or warning for me:
struct Corner
int X;
int Y;
int Z;
Corner Corners[8];
Corners[0].X = 0;
void loop() {}
Because you put the assignment statement inside a function. OP's (incorrectly posted) code snippet doesn't.
@johnwasser's code looked wrong to me, of course I never argue with success.
Turns out I'm just an old C programmer. That doesn't work in C. I found this looking around to learn up a bit, well to try anyway.
which g0es into some C and C++ differences as well as other improvements visited upon us over the years.
I will probably use
typedef struct
int X;
int Y;
int Z;
} Corner;
Corner Corners[8];
no matter what I manage to learn.
Octagon?
a7
It is very long.... ![]()
O.. It needs to be in setup();
I had it before.... just like other variables?
maybe stupid question... but i had this...:
int NewX[12] = {0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 30 , 0 , -30 , 0};
int NewY[12] = {0 , 0 , 0 , 0 , 20 , 0 , -20, 0 , 0 , 0 , 0 , 0};
int NewZ[12] = {30 , 0 , -30, 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0};
struct hoek {
int X;
int Y;
int Z;
struct hoek Corners[8];
//Corners[0].X = 0;
I mean, the 3 Arrays... and I want it in one struct array... so I try it in the same place...
now, if I put the Corners{0].X=0 in Setup(0) I don't get any errors ....
When you declared your int arrays and initialized them, you did it in one go.
For your struct array, you didn't and the compiler doesn't like that.
and if I want it in that place...? is that possible? and how do I do that? (if it is possible)
struct hoek Corners[12] =
{0, 0, 30},
{0,0,0},
{0,0,-30},
{0,0,0},
{0, 20, 0},
{0,0,0},
{0,-20,0},
{0,0,0},
{30,0,0},
{0,0,0},
{-30,0,0},
{0,0,0}
thanks.... now it works... ![]()
next question about structs....
is it also possible to give a struct result out of a function?
and yes, how?
so I mean, I have a function... start it with some values to the function... and I want back a X,Y,Z value?
Hello
That is referenced as call by reference.
Take a view into a C++ tutorial.
I don’t enjoy coding in C++
but 65 seconds of googling make me think
in C++ you can pass a struct to a function and a function can return a struct to the caller by using syntax indistinguishable from that used to pass and return ints.
If I’m wrong, I am sure someone will fix me up on that.
a7
Declare it as:
struct hoek Function() {}
For example:
struct hoek
int X;
int Y;
int Z;
{0, 0, 30},
{0, 0, 0},
{0, 0, -30},
{0, 0, 0},
{0, 20, 0},
{0, 0, 0},
{0, -20, 0},
{0, 0, 0},
{30, 0, 0},
{0, 0, 0},
{ -30, 0, 0},
{0, 0, 0}
delay(200);
struct hoek returnVal = Function(0);
Serial.print(returnVal.X);
Serial.print(", ");
Serial.print(returnVal.Y);
Serial.print(", ");
Serial.println(returnVal.Z);
void loop() {}
struct hoek Function(int index)
return Corners[index];
Or not, kinda. Odd that it was in this thread that I learned a tiny bit of C++...
Declare it as:
hoek Function() {}
Compiles and produces identical results:
struct hoek
int X;
int Y;
int Z;
hoek Corners[12] =
{0, 0, 30},
{0, 0, 0},
{0, 0, -30},
{0, 0, 0},
{0, 20, 0},
{0, 0, 0},
{0, -20, 0},
{0, 0, 0},
{30, 0, 0},
{0, 0, 0},
{ -30, 0, 0},
{0, 0, 0}
delay(200);
Serial.print(", ");
Serial.print(", ");
void loop() {}
Same syntax as used for ints, C++ means no struct and no need for the C typedef.
a7
