I've tried reinstalling it with and without antivirus activated, but it doesn't get past loading screen.
I'm on windows 11, notebook ideapad s145. The funny thing is when I installed it on my desktop, that is also windows 11, it worked fine, no antivirus deactivation needed.
After using this command:
& ".\Arduino IDE"
On my arduino folder I got this result.
PS C:\Users\ivant\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.4
Starting backend process. PID: 20328
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/ivant/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-03-13T14:04:06.586Z root INFO Backend Object.initialize: 7.3 ms [Finished 1.971 s after backend start]
2023-03-13T14:04:06.587Z root INFO Backend Object.configure: 5.5 ms [Finished 1.971 s after backend start]
2023-03-13T14:04:06.587Z root INFO Backend MessagingContribution.onStart: 2.4 ms [Finished 1.971 s after backend start]
2023-03-13T14:04:06.589Z root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 2.021 s after backend start]
2023-03-13T14:04:06.589Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 2.022 s after backend start]
2023-03-13T14:04:06.592Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 2.022 s after backend start]
2023-03-13T14:04:06.594Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 50.2 ms [Finished 2.022 s after backend start]
2023-03-13T14:04:06.595Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.3 ms [Finished 2.022 s after backend start]
2023-03-13T14:04:06.596Z root INFO Backend ElectronTokenBackendContribution.configure: 1.7 ms [Finished 2.024 s after backend start]
2023-03-13T14:04:06.597Z config INFO >>> Initializing CLI configuration...
2023-03-13T14:04:06.597Z root INFO Backend PluginDeployerContribution.initialize: 1.1 ms [Finished 2.024 s after backend start]
2023-03-13T14:04:06.598Z root INFO Backend ConfigServiceImpl.onStart: 1.3 ms [Finished 2.025 s after backend start]
2023-03-13T14:04:06.599Z config INFO Loading CLI configuration from c:\Users\ivant\.arduinoIDE\arduino-cli.yaml...
2023-03-13T14:04:06.600Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 1.3 ms [Finished 2.028 s after backend start]
2023-03-13T14:04:06.601Z root INFO Backend ArduinoDaemonImpl.onStart: 2.7 ms [Finished 2.030 s after backend start]
2023-03-13T14:04:06.601Z root INFO Backend NodeFileUploadService.configure: 5.3 ms [Finished 2.030 s after backend start]
2023-03-13T14:04:06.601Z daemon INFO Starting daemon from C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-03-13T14:04:06.601Z discovery-log INFO start
2023-03-13T14:04:06.602Z discovery-log INFO start new deferred
2023-03-13T14:04:06.602Z root INFO Backend HostedPluginLocalizationService.initialize: 0.8 ms [Finished 2.032 s after backend start]
2023-03-13T14:04:06.602Z root INFO Backend BoardDiscovery.onStart: 1.6 ms [Finished 2.033 s after backend start]
2023-03-13T14:04:06.602Z root INFO Backend FileDownloadEndpoint.configure: 1.4 ms [Finished 2.034 s after backend start]
2023-03-13T14:04:06.603Z root INFO Backend AuthenticationServiceImpl.onStart: 0.8 ms [Finished 2.036 s after backend start]
2023-03-13T14:04:06.603Z root INFO Backend PluginApiContribution.configure: 0.8 ms [Finished 2.036 s after backend start]
2023-03-13T14:04:06.605Z root INFO Backend HostedPluginReader.configure: 0.7 ms [Finished 2.038 s after backend start]
2023-03-13T14:04:06.605Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 2.038 s after backend start]
2023-03-13T14:04:06.605Z root INFO Backend PlotterBackendContribution.configure: 1.7 ms [Finished 2.040 s after backend start]
2023-03-13T14:04:06.612Z root INFO Theia app listening on http://localhost:52906.
2023-03-13T14:04:06.613Z root INFO Finished starting backend application: 10.8 ms [Finished 2.048 s after backend start]
2023-03-13T14:04:06.632Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ivant/.arduinoIDE/plugins does not exist.
2023-03-13T14:04:06.633Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ivant/.arduinoIDE/extensions does not exist.
2023-03-13T14:04:06.634Z root WARN The local plugin referenced by local-dir:C:\Users\ivant\.arduinoProIDE\plugins does not exist.
2023-03-13T14:04:06.667Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.667Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-03-13T14:04:06.668Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.7" with engines:
2023-03-13T14:04:06.668Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.668Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-03-13T14:04:06.668Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-03-13T14:04:06.668Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-03-13T14:04:06.669Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-03-13T14:04:06.669Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.669Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-03-13T14:04:06.669Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-03-13T14:04:06.669Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-03-13T14:04:06.670Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.670Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-03-13T14:04:06.670Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-03-13T14:04:06.670Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-03-13T14:04:06.670Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-03-13T14:04:06.671Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.671Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-03-13T14:04:06.671Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-03-13T14:04:06.671Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-03-13T14:04:06.672Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-03-13T14:04:06.672Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.672Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-03-13T14:04:06.672Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-03-13T14:04:06.673Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-03-13T14:04:06.673Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-13T14:04:06.673Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-03-13T14:04:06.685Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\ivant\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\ivant\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\ivant\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-03-13T14:04:06.685Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-03-13T14:04:06.686Z config INFO Loaded the CLI configuration.
2023-03-13T14:04:06.687Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/ivant/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/ivant/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-03-13T14:04:06.688Z config INFO Validating the CLI configuration...
2023-03-13T14:04:06.689Z config INFO The CLI config is valid.
2023-03-13T14:04:06.689Z config INFO <<< Initialized the CLI configuration.
2023-03-13T14:04:06.782Z daemon INFO INFO[0000] Using config file: c:\Users\ivant\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.31.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"52907"}
2023-03-13T14:04:06.784Z daemon INFO Daemon is running.
2023-03-13T14:04:06.813Z root INFO Resolve plugins list: 212.7 ms [Finished 2.247 s after backend start]
2023-03-13T14:04:06.831Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 19.0 ms [Finished 2.267 s after backend start]
2023-03-13T14:04:06.832Z daemon INFO INFO[0000] Loading hardware from: C:\Users\ivant\AppData\Local\Arduino15\packages
INFO[0000] Loading libraries index file index="C:\\Users\\ivant\\AppData\\Local\\Arduino15\\library_index.json"
INFO[0000] Adding libraries dir dir="C:\\Users\\ivant\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="C:\\Users\\ivant\\Documents\\Arduino\\libraries" location=user
2023-03-13T14:04:06.834Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\ivant\AppData\Local\Arduino15\package_index.json: open C:\Users\ivant\AppData\Local\Arduino15\package_index.json: O sistema não pode encontrar o arquivo especificado.
2023-03-13T14:04:06.835Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2023-03-13T14:04:06.836Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2023-03-13T14:04:06.837Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\ivant\AppData\Local\Arduino15\library_index.json: O sistema não pode encontrar o arquivo especificado.
2023-03-13T14:04:06.843Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-03-13T14:04:06.851Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.7" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 19.8 ms [Finished 2.287 s after backend start]
2023-03-13T14:04:06.852Z daemon INFO INFO[0000] Updating libraries index
INFO[0000] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
INFO[0000] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
INFO[0000] Starting download url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2023-03-13T14:04:06.855Z root INFO core-client-provider [platform-index]
2023-03-13T14:04:06.856Z root INFO core-client-provider [library-index]
2023-03-13T14:04:06.873Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 21.4 ms [Finished 2.308 s after backend start]
2023-03-13T14:04:06.878Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 5.1 ms [Finished 2.313 s after backend start]
2023-03-13T14:04:06.879Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.6 ms [Finished 2.315 s after backend start]
2023-03-13T14:04:07.020Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 140.4 ms [Finished 2.456 s after backend start]
2023-03-13T14:04:07.024Z root ERROR Failed to update platform, library indexes.
2023-03-13T14:04:07.034Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\ivant\AppData\Local\Arduino15\package_index.json: open C:\Users\ivant\AppData\Local\Arduino15\package_index.json: O sistema não pode encontrar o arquivo especificado.
2023-03-13T14:04:07.035Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2023-03-13T14:04:07.035Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2023-03-13T14:04:07.036Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\ivant\AppData\Local\Arduino15\library_index.json: O sistema não pode encontrar o arquivo especificado.
2023-03-13T14:04:07.039Z root ERROR Uncaught Exception:
2023-03-13T14:04:07.039Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\ivant\AppData\Local\Arduino15\package_index.json: open C:\Users\ivant\AppData\Local\Arduino15\package_index.json: O sistema não pode encontrar o arquivo especificado.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\ivant\AppData\Local\Arduino15\library_index.json: O sistema não pode encontrar o arquivo especificado.
at isIndexUpdateRequiredBeforeInit (C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:388:11)
at CoreClientProvider.evaluateErrorStatus (C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:200:16)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async ClientReadableStreamImpl.<anonymous> (C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:184:31)
2023-03-13T14:04:07.044Z daemon INFO INFO[0000] Loading hardware from: C:\Users\ivant\AppData\Local\Arduino15\packages
2023-03-13T14:04:07.184Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 164.0 ms [Finished 2.620 s after backend start]
2023-03-13T14:04:07.341Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 156.4 ms [Finished 2.776 s after backend start]
2023-03-13T14:04:07.445Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 104.0 ms [Finished 2.880 s after backend start]
2023-03-13T14:04:07.534Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 89.6 ms [Finished 2.970 s after backend start]
2023-03-13T14:04:07.604Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 69.8 ms [Finished 3.040 s after backend start]
2023-03-13T14:04:07.677Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 72.5 ms [Finished 3.112 s after backend start]
2023-03-13T14:04:07.764Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 87.4 ms [Finished 3.200 s after backend start]
2023-03-13T14:04:07.855Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 90.8 ms [Finished 3.291 s after backend start]
2023-03-13T14:04:07.909Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 54.2 ms [Finished 3.345 s after backend start]
2023-03-13T14:04:07.995Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 85.2 ms [Finished 3.430 s after backend start]
2023-03-13T14:04:08.078Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 83.2 ms [Finished 3.514 s after backend start]
2023-03-13T14:04:08.166Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 87.6 ms [Finished 3.601 s after backend start]
2023-03-13T14:04:08.245Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 79.0 ms [Finished 3.680 s after backend start]
2023-03-13T14:04:08.298Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 53.0 ms [Finished 3.733 s after backend start]
2023-03-13T14:04:08.393Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\ivant\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 81.7 ms [Finished 3.815 s after backend start]
2023-03-13T14:04:08.393Z root INFO Deploy plugins list: 212.7 ms [Finished 3.828 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-03-13T14:04:09.446Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 335.6 ms [Finished 2.688 s after frontend start]
What am i suposed to do now?
