Arduino ide 2.0.3 blank screen
the other day i started having issues with arduino loading then going to a blank screen wasn't able to close it unless i went into task manager to end process i was getting sick and tired of having to do it so i removed arduino completly and installed a fresh clean copy only to find that it's doing the same thing here is the power shell report
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE".
Arduino IDE 2.0.3
Starting backend process. PID: 19460
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/61415/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2022-12-19T05:13:51.678Z root INFO Backend Object.initialize: 4.3 ms [Finished 1.107 s after backend start]
2022-12-19T05:13:51.678Z root INFO Backend Object.configure: 3.5 ms [Finished 1.107 s after backend start]
2022-12-19T05:13:51.679Z root INFO Backend MessagingContribution.onStart: 1.7 ms [Finished 1.107 s after backend start]
2022-12-19T05:13:51.680Z root INFO Backend OSBackendApplicationContribution.configure: 0.1 ms [Finished 1.139 s after backend start]
2022-12-19T05:13:51.681Z root INFO Backend DefaultWorkspaceServer.onStart: 0.1 ms [Finished 1.139 s after backend start]
2022-12-19T05:13:51.682Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.139 s after backend start]
2022-12-19T05:13:51.682Z root INFO Backend PluginLocalizationBackendContribution.initialize: 32.3 ms [Finished 1.139 s after backend start]
2022-12-19T05:13:51.683Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.139 s after backend start]
2022-12-19T05:13:51.684Z root INFO Backend ElectronTokenBackendContribution.configure: 1.6 ms [Finished 1.141 s after backend start]
2022-12-19T05:13:51.684Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.141 s after backend start]
2022-12-19T05:13:51.685Z root INFO Backend ConfigServiceImpl.onStart: 1.0 ms [Finished 1.142 s after backend start]
2022-12-19T05:13:51.686Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.143 s after backend start]
2022-12-19T05:13:51.686Z root INFO Backend ArduinoDaemonImpl.onStart: 1.0 ms [Finished 1.144 s after backend start]
2022-12-19T05:13:51.686Z root INFO Backend NodeFileUploadService.configure: 2.0 ms [Finished 1.144 s after backend start]
2022-12-19T05:13:51.687Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2022-12-19T05:13:51.687Z discovery-log INFO start
2022-12-19T05:13:51.687Z discovery-log INFO start new deferred
2022-12-19T05:13:51.687Z root INFO Backend HostedPluginLocalizationService.initialize: 0.5 ms [Finished 1.145 s after backend start]
2022-12-19T05:13:51.687Z root INFO Backend BoardDiscovery.onStart: 0.9 ms [Finished 1.146 s after backend start]
2022-12-19T05:13:51.687Z root INFO Backend FileDownloadEndpoint.configure: 0.8 ms [Finished 1.146 s after backend start]
2022-12-19T05:13:51.688Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.147 s after backend start]
2022-12-19T05:13:51.688Z root INFO Backend PluginApiContribution.configure: 0.5 ms [Finished 1.148 s after backend start]
2022-12-19T05:13:51.692Z root INFO Backend HostedPluginReader.configure: 0.5 ms [Finished 1.149 s after backend start]
2022-12-19T05:13:51.692Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.149 s after backend start]
2022-12-19T05:13:51.692Z root INFO Backend PlotterBackendContribution.configure: 0.8 ms [Finished 1.153 s after backend start]
2022-12-19T05:13:51.695Z root INFO Theia app listening on http://localhost:50429.
2022-12-19T05:13:51.695Z root INFO Finished starting backend application: 7.9 ms [Finished 1.156 s after backend start]
2022-12-19T05:13:51.696Z root WARN The local plugin referenced by local-dir:/c%3A/Users/61415/.arduinoIDE/plugins does not exist.
2022-12-19T05:13:51.696Z root WARN The local plugin referenced by local-dir:/c%3A/Users/61415/.arduinoIDE/extensions does not exist.
2022-12-19T05:13:51.697Z root WARN The local plugin referenced by local-dir:C:\Users\61415\.arduinoProIDE\plugins does not exist.
2022-12-19T05:13:51.718Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.719Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2022-12-19T05:13:51.723Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.728Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2022-12-19T05:13:51.728Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.729Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2022-12-19T05:13:51.729Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.730Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2022-12-19T05:13:51.730Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.731Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2022-12-19T05:13:51.731Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.731Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2022-12-19T05:13:51.732Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.734Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2022-12-19T05:13:51.738Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.739Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2022-12-19T05:13:51.740Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.742Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2022-12-19T05:13:51.742Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.743Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2022-12-19T05:13:51.744Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.747Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2022-12-19T05:13:51.751Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.753Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2022-12-19T05:13:51.754Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.755Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2022-12-19T05:13:51.756Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.763Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2022-12-19T05:13:51.764Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.769Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2022-12-19T05:13:51.771Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.771Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2022-12-19T05:13:51.773Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.777Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2022-12-19T05:13:51.777Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.777Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2022-12-19T05:13:51.778Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.778Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2022-12-19T05:13:51.779Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.779Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2022-12-19T05:13:51.782Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-19T05:13:51.785Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2022-12-19T05:13:51.818Z root INFO Resolve plugins list: 132.4 ms [Finished 1.279 s after backend start]
2022-12-19T05:13:51.824Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 5.8 ms [Finished 1.285 s after backend start]
2022-12-19T05:13:51.828Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 4.7 ms [Finished 1.290 s after backend start]
2022-12-19T05:13:51.840Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 10.9 ms [Finished 1.301 s after backend start]
2022-12-19T05:13:51.842Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.6 ms [Finished 1.303 s after backend start]
2022-12-19T05:13:51.843Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.0 ms [Finished 1.304 s after backend start]
2022-12-19T05:13:51.930Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 86.0 ms [Finished 1.391 s after backend start]
2022-12-19T05:13:51.952Z daemon INFO INFO[0000] Using config file: c:\Users\61415\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.29.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"50431"}
2022-12-19T05:13:51.955Z daemon INFO Daemon is running.
2022-12-19T05:13:52.046Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 116.8 ms [Finished 1.507 s after backend start]
2022-12-19T05:13:52.054Z daemon INFO INFO[0000] Loading hardware from: c:\Users\61415\AppData\Local\Arduino15\packages
2022-12-19T05:13:52.058Z daemon INFO INFO[0000] Loading package ATTinyCore from: C:\Users\61415\AppData\Local\Arduino15\packages\ATTinyCore\hardware
2022-12-19T05:13:52.165Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 118.4 ms [Finished 1.626 s after backend start]
2022-12-19T05:13:52.166Z daemon INFO INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\installed.json" signatureFile="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\installed.json.sig"
INFO[0000] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform                               platform="ATTinyCore:avr@1.5.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\61415\AppData\Local\Arduino15\packages\ATTinyCore\tools
INFO[0000] Loading tools from dir: C:\Users\61415\AppData\Local\Arduino15\packages\ATTinyCore\tools
INFO[0000] Loaded tool                                   tool="ATTinyCore:micronucleus@2.5-azd1b"
INFO[0000] Loading package arduino from: C:\Users\61415\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Loaded platform                               platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\61415\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\61415\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino18"
INFO[0000] Loading package attiny from: C:\Users\61415\AppData\Local\Arduino15\packages\attiny\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\installed.json" signatureFile="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\attiny\\hardware\\avr\\1.0.2\\installed.json.sig"
INFO[0000] Loaded platform                               platform="attiny:avr@1.0.2"
INFO[0000] Loading package builtin from: C:\Users\61415\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\61415\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\61415\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.11.0"
INFO[0000] Loading package esp32 from: C:\Users\61415\AppData\Local\Arduino15\packages\esp32\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\installed.json" signatureFile="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\installed.json.sig"
INFO[0000] Loaded platform                               platform="esp32:esp32@2.0.5"
INFO[0000] Checking existence of 'tools' path: C:\Users\61415\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loading tools from dir: C:\Users\61415\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loaded tool                                   tool="esp32:esptool_py@4.2.1"
INFO[0000] Loaded tool                                   tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0000] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0000] Loaded tool                                   tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32s3-elf-gcc@gcc8_4_0-esp-2021r2-patch3"
INFO[0000] Loading package esp8266 from: C:\Users\61415\AppData\Local\Arduino15\packages\esp8266\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\installed.json.sig: The system cannot find the file specified." index="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\installed.json" signatureFile="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\installed.json.sig"
INFO[0000] Loaded platform                               platform="esp8266:esp8266@3.0.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\61415\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0000] Loading tools from dir: C:\Users\61415\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0000] Loaded tool                                   tool="esp8266:mklittlefs@3.0.4-gcc10.3-1757bed"
INFO[0000] Loaded tool                                   tool="esp8266:mkspiffs@3.0.4-gcc10.3-1757bed"
INFO[0000] Loaded tool                                   tool="esp8266:python3@3.7.2-post1"
INFO[0000] Loaded tool                                   tool="esp8266:xtensa-lx106-elf-gcc@3.0.4-gcc10.3-1757bed"
INFO[0000] Checking signature                            index="c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Checking signature                            error="opening signature file: open c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_drazzy.com_index.json.sig: The system cannot find the file specified." index="c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_drazzy.com_index.json" signatureFile="c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_drazzy.com_index.json.sig"
INFO[0000] Checking signature                            error="opening signature file: open c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified." index="c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_esp32_index.json" signatureFile="c:\\Users\\61415\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig"
INFO[0000] Adding libraries dir                          dir="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\libraries" location=platform
2022-12-19T05:13:52.173Z daemon INFO INFO[0000] Adding libraries dir                          dir="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\61415\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries" location=platform
INFO[0000] Loading libraries index file                  index="c:\\Users\\61415\\AppData\\Local\\Arduino15\\library_index.json"
2022-12-19T05:13:52.248Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 83.1 ms [Finished 1.709 s after backend start]
2022-12-19T05:13:52.292Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 44.2 ms [Finished 1.753 s after backend start]
2022-12-19T05:13:52.338Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 46.0 ms [Finished 1.799 s after backend start]
2022-12-19T05:13:52.411Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 72.7 ms [Finished 1.872 s after backend start]
2022-12-19T05:13:52.412Z daemon INFO INFO[0000] Adding libraries dir                          dir="C:\\Users\\61415\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir                          dir="c:\\Users\\61415\\Documents\\Arduino\\libraries" location=user
2022-12-19T05:13:52.464Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 53.1 ms [Finished 1.925 s after backend start]
2022-12-19T05:13:52.513Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 49.2 ms [Finished 1.975 s after backend start]
2022-12-19T05:13:52.533Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 19.9 ms [Finished 1.995 s after backend start]
2022-12-19T05:13:52.584Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 50.3 ms [Finished 2.045 s after backend start]
2022-12-19T05:13:52.633Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 49.2 ms [Finished 2.094 s after backend start]
2022-12-19T05:13:52.689Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 55.9 ms [Finished 2.150 s after backend start]
2022-12-19T05:13:52.751Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 62.3 ms [Finished 2.213 s after backend start]
2022-12-19T05:13:52.789Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 37.5 ms [Finished 2.250 s after backend start]
2022-12-19T05:13:52.841Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 51.9 ms [Finished 2.302 s after backend start]
2022-12-19T05:13:52.842Z root INFO Deploy plugins list: 132.4 ms [Finished 2.303 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2022-12-19T05:13:53.703Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 200.2 ms [Finished 1.925 s after frontend start]
2022-12-19T05:13:53.913Z root INFO Start frontend contributions: 493.7 ms [Finished 2.125 s after frontend start]
2022-12-19T05:13:53.914Z root INFO Changed application state from 'init' to 'started_contributions'.
2022-12-19T05:13:53.930Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2022-12-19T05:13:53.930Z root INFO >>> Restoring the layout state...
2022-12-19T05:13:53.931Z root INFO <<< Nothing to restore.
2022-12-19T05:13:53.972Z root INFO Initialize the workbench layout: 33.1 ms [Finished 2.219 s after frontend start]
2022-12-19T05:13:53.989Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2022-12-19T05:13:54.008Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2] Waiting for backend deployment: 137.5 ms [Finished 2.258 s after frontend start]
2022-12-19T05:13:54.510Z root INFO [hosted-plugin: 19928] PLUGIN_HOST(19928) starting instance
2022-12-19T05:13:54.521Z discovery-log INFO start request start watch
2022-12-19T05:13:54.522Z discovery-log INFO start requested start watch
2022-12-19T05:13:54.523Z discovery-log INFO start resolved watching
2022-12-19T05:13:54.536Z daemon INFO INFO[0002] starting discovery builtin:serial-discovery process
INFO[0002] starting discovery builtin:mdns-discovery process
2022-12-19T05:13:54.549Z daemon INFO INFO[0002] started discovery builtin:serial-discovery process
INFO[0002] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:serial-discovery
INFO[0002] started discovery builtin:mdns-discovery process
INFO[0002] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:mdns-discovery
2022-12-19T05:13:54.556Z daemon INFO INFO[0002] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0002] sending command START_SYNC to discovery builtin:serial-discovery
2022-12-19T05:13:54.560Z daemon INFO INFO[0002] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0002] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0002] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
INFO[0002] from discovery builtin:serial-discovery received message type: start_sync, message: OK
2022-12-19T05:13:54.570Z daemon INFO INFO[0002] from discovery builtin:serial-discovery received message type: add, port: COM8
2022-12-19T05:13:55.001Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2] Sync of 21 plugins: 972.0 ms [Finished 3.230 s after frontend start]
2022-12-19T05:13:55.004Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][marus25.cortex-debug]: Loaded contributions.
2022-12-19T05:13:55.006Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][arduino.vscode-arduino-tools]: Loaded contributions.
2022-12-19T05:13:55.008Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][vscode.cpp]: Loaded contributions.
2022-12-19T05:13:55.009Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][vscode.json]: Loaded contributions.
2022-12-19T05:13:55.011Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][vscode.json-language-features]: Loaded contributions.
2022-12-19T05:13:55.012Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2022-12-19T05:13:55.014Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2022-12-19T05:13:55.018Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2022-12-19T05:13:55.019Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2022-12-19T05:13:55.020Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2022-12-19T05:13:55.020Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2022-12-19T05:13:55.021Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2022-12-19T05:13:55.021Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2022-12-19T05:13:55.022Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2022-12-19T05:13:55.030Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2022-12-19T05:13:55.031Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2022-12-19T05:13:55.031Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2022-12-19T05:13:55.032Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2022-12-19T05:13:55.032Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2022-12-19T05:13:55.033Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2022-12-19T05:13:55.038Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2022-12-19T05:13:55.045Z root INFO [1a392b2f-2c51-4f62-8e33-69d1413663b2] Load contributions of 21 plugins: 26.0 ms [Finished 3.256 s after frontend start]
2022-12-19T05:13:55.407Z root INFO Replace loading indicator with ready workbench UI (animation): 1069.8 ms [Finished 3.298 s after frontend start]
2022-12-19T05:13:55.408Z root INFO Changed application state from 'initialized_layout' to 'ready'.
Checking for update
2022-12-19T05:13:55.415Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2022-12-19T05:13:55.416Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2022-12-19T05:13:55.417Z root WARN a registered grammar configuration for 'cpp' language is overridden
2022-12-19T05:13:55.434Z root INFO Frontend application start: 1743.0 ms [Finished 4.862 s after backend start]
[10632:1219/161355.772:ERROR:crashpad_client_win.cc(808)] not connected
2022-12-19T05:13:56.399Z root ERROR ---- !!!SLOW!!! DURATION: search took 873.848 ms. Args: [{"type":"Updatable"}] ----
2022-12-19T05:13:56.405Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x7523"],["serialNumber",""],["vid","0x1A86"]]}},"error":""}
Update for version 2.0.3 is not available (latest version: 2.0.3, downgrade is allowed).
Error sending from webFrameMain:  Error: Render frame was disposed before WebFrameMain could be accessed
    at Object.n.send (node:electron/js2c/browser_init:169:417)
    at Object.b.send (node:electron/js2c/browser_init:165:2492)
    at C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\electron-main\messaging\electron-messaging-contribution.js:143:29
    at C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\event.js:103:69
    at CallbackList.invoke (C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\event.js:109:26)
    at Emitter.fire (C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\event.js:224:29)
    at Uint8ArrayWriteBuffer.commit (C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\message-rpc\uint8-array-message-buffer.js:91:30)
    at RpcProtocol.sendNotification (C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\message-rpc\rpc-protocol.js:125:16)
    at C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\messaging\proxy-factory.js:215:36
    at new Promise (<anonymous>)
    at RpcProtocol.handleRequest (C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\core\lib\common\message-rpc\rpc-protocol.js:153:20)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
sendToFrame() failed: Error: Render frame was disposed before WebFrameMain could be accessed
[18216:1219/161550.695:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is```
i'm still having these issues on my main computer
