Having a bit of a senior moment.
Using the stainless steel pressure sensor and the gravity analog current to voltage converter with the following software that is on the site.
What I would like is, instead of reading up to 5000mm (5m) I would like it go to 10m(10000mm) but to show metres with 2 decimal points instead of mm with 2 decimal points.
This is because I have both a 5m and 10m sensor to try
Thank you for any assistance
Software seems to work:-
DFRobot Gravity: Analog Current to Voltage Converter(For 4~20mA Application)
SKU:SEN0262
GNU Lesser General Public License.
See <http://www.gnu.org/licenses/> for details.
All above must be included in any redistribution
#define ANALOG_PIN A2
#define RANGE 5000 // Depth measuring range 5000mm (for water)
#define VREF 5000 // ADC's reference voltage on your Arduino,typical value:5000mV
#define CURRENT_INIT 4.00 // Current @ 0mm (uint: mA)
#define DENSITY_WATER 1 // Pure water density normalized to 1
#define DENSITY_GASOLINE 0.74 // Gasoline density
#define PRINT_INTERVAL 1000
int16_t dataVoltage;
float dataCurrent, depth; //unit:mA
unsigned long timepoint_measure;
pinMode(ANALOG_PIN, INPUT);
timepoint_measure = millis();
if (millis() - timepoint_measure > PRINT_INTERVAL) {
dataVoltage = analogRead(ANALOG_PIN)/ 1024.0 * VREF;
dataCurrent = dataVoltage / 120.0; //Sense Resistor:120ohm
depth = (dataCurrent - CURRENT_INIT) * (RANGE/ DENSITY_WATER / 16.0); //Calculate depth from current readings
if (depth < 0)
depth = 0.0;
//Serial print results
Serial.print("depth:");
Serial.print(depth);
Serial.println("mm");
