All good now - I had the wrong driver selected !
I have been using Bodmer's TFT eSPI library with great success on STM32F401 - now I'm migrating my code to a Blackpill F411 and need to use SPI2 (SPI1 is used for a W5500 ethernet connection).
I've edited Setup29_ILI9341_stm32.h and can see signals on the correct pins for SPI2 as per below
#define TFT_SPI_PORT 2 // SPI 2 maximum clock rate is 27MHz
#define TFT_MOSI PB15
#define TFT_MISO PB14 // was pc2
#define TFT_SCLK PB13
#define TFT_CS PB10 // Chip select control pin to TFT CS
#define TFT_DC PB4 // Data Command control pin to TFT DC (may be labelled RS = Register Select)
#define TFT_RST PB5 // Reset pin to TFT RST (or RESET)
Any ideas / suggestions ?
I'm using Arduino IDE 2.2.1 and TFT eSPI 2.5.31
Regards Tim
