Working on a project which includes an SSD1306 & rotary encoder (with pushbutton) where I'm wanting the following, but unsure the best way to go about it.
On startup, show static title + the current value of 3 variables (This I e already done)
Pushing the rotary encoder button shows a menu listing 3 variables (different than above) which you may change value of using rotary encoder followed by a "Back" button which takes you back to the title screen
As mentioned, I've got the title screen how I want it plus rotary encoder working - just need to get the single sub-menu. I found a few examples online for menus, but all of them start with a menu - not a title / status page. Ran across the arduino-menusystem library plus got this project working, but so far no luck getting it to work the way i want & perhaps overkill what what I'm wanting.
To note, the project uses a lot of resources and have read menusystem is hungry so if theres a lighter choice, that would be great.
It is designed for LCD module displays but I have it working on an OLED as well. The title screen and menu are managed by your application and you can have them share the same resource.
Thanks - Looking into it. Looking into U8g2lib as well.
I think my biggest hurdle is how to make it start at the info/title screen then go to the menu after click. If starting with a menu, it would be a lot simpler.
The examples in MD_Menu all flip from a 'normal' display to menu and show how to manage this. When you have only got 2 lines on a display sharing the display with the menu is not an option
