Hello everyone!
This thread is a follow up to this project : Driving stepper motor with Arduino and A4988 - Project Guidance - Arduino Forum
I made a bit of progress since then by streamlining the code, adding a solenoid valve, a switch for the power supply, and I tried to implement remotely supplying the Arduino via its Jack port. Here is the current scheme of the circuit :
Just to clarify, the two wires coming out of the rotary encoder (on the bottom) are 2 extra pins for the central push button.
I am using a buck-converter (https://www.gotronic.fr/art-regulateur-ajustable-1-25-a-30-v-ef03061-23543.htm) as a way to step-down the voltage coming from the power supply (24V, 1A).
The issue that I am currently facing is that when I plug the whole prototype with the power supply, everything turns on no problem : the ON LED from the Arduino turns on, the Nokia 5110 screen turns on (but the backlight is very dim) and for some reason the motor starts slowly spinning although no command was sent to do so (The motor is controlled via a menu interface on the LCD screen)... But stops running after 2-3 seconds.
I instantly thought that this might be an issue from the buck-converter stepping down the voltage too much, so I tried to play a little bit with the screw from the potentiometer to change the output voltage, but I am afraid of destroying the circuit, and for the moment I do not have a multimeter available to test the output voltage.
I was just wondering if the problem was coming from the buck-converter as I mentioned previously or from the wiring diagram itself, maybe I fucked-up some of the connections? I wanted to have the point of view from experts!
P.S : the circuit that I was using previously, powering the Arduino with the USB cable and my laptop works perfectly! Here is a scheme of 'stable' version of the prototype :
If you have any ideas,
Thank you in advance!
Best,
Tom
