Hi guys
I'm working on a project where I have a distributed supply voltage of 12VDC. My components (µC, sensors,...) need 3.3VDC with a load between 10 and 150mA. I will also connect some addressable LEDs (maximum 6), those need 5VDC and if they are all at full brightness, that can end up to around 360mA. The LEDs will not be powered all the time, only when there is interaction with the unit (probably periods of 1 minute, 4-5 times per hour), so the µC will switch that rail on/off when needed.
There will be 30-40 of these units, and they will be operational 24/7. I'm looking for the most efficient way to create these 3.3VDC and 5VDC supply rails.
What I have looked into are:
- Buck converters
- LDOs
- Capacitor booster
To quantify the most efficient way, I'm taking these factors into account
- Supply efficiency
- PCB real estate
- Price
- Part count (although that is probably automatically covered by the previous 2)
I already had 4 ideas, but have no experience in selecting these components (when there is actual design criteria), so maybe I don't take everything into account.
3.3VDC LDO + 5VDC LDO
Probably the cheapest and easiest solution, but because of the 'high' 12VDC supply voltage, not very efficient. -
3.3VDC Buck + 5VDC LDO
The buck converter will be on at all time, so give away some PCB real estate for an increase in efficiency. 5VDC is only needed for short amounts of time, so ignore the loss in efficiency.
Maybe use one of those buck converters with integrated inductor, to decrease the PCB real estate, at an additional cost. -
3.3VDC Buck + 5VDC Buck
Highest efficiency, but maybe becomes too bulky/pricy -
3.3VDC Buck + 5VDC Capacitor boost
Seems a bit strange to go down in voltage, and back up again, but maybe a good compromise to get an overal high efficiency? The 3.3VDC converter does need to be specced for a higher power rating, so maybe very inefficient at low loads.
If anybody can chime in on what route to take in this project, that would be great!
Thanks
Tom
