Supplying arduino UNO with 5 volts
I have an AC to DV adapter that supplies 5volts and a maximum current of 1000mA with a positive polarity
is it okay to plug it in the Arduino Uno Power Jack ??
No. The power jack feeds the on-board 5V regulator which needs about 7V to produce 5V.
I think your Arduino might work on whatever voltage gets trough the regulator but it won't be running on 5V
You can connect 5V to the +5V and Gnd pins. There is a slight chance this might damage the 5V regulator but the risk is low.
johnwasser:
Agree,
NCP1117ST50T3G works at 5 V need Vin >= 6.5V and D1 has 0.5V voltage drop, total is 7.0V.
If it's a regulated supply (measure it with no load, see if it's outputting 5V) then you can connect it to the Arduino Vin pin.
You should test it out with a voltmeter/multimeter first, but I've done it with successful results before.
-Mr_E
fungus:
If it's a regulated (5V) supply (measure it with no load, see if it's outputting 5V) then you can connect it to the Arduino Vin pin.
Not the Vin pin, the +5V pin.
johnwasser:
fungus:
true. the vin pin feeds directly to the barrel jack. if you snip the wires and stick the positive into the 5v pin it will work.(be 100% sure that is is a more or less stable supply of 5v exactly.)
You should not connect a supply to the 5V pin and use USB at the same time, however.
And to further cloud the issue the arduino product page for the Uno says you should not supply external +5vdc to the shield 5V pin, but without further official explanation:
5V.This pin outputs a regulated 5V from the regulator on the board. The board can be supplied with power either from the DC power jack (7 - 12V), the USB connector (5V), or the VIN pin of the board (7-12V). Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and can damage your board. We don't advise it.
Lefty
There are three types USB cables;-
  • data-only USB cable ( no 5 v)
  • USB Charging Cable (no data)
  • Standard USB cable
Use USB Charging Cable supplying arduino UNO with 5 volts power.
