Hello, is there any way to obtain SVG's or STL's for a pcb drawing. Kind of like a stencil for the PCB. Here is my picture (in PDF and PNG format) of the PCB.
PCB_PCB_Arudino-shield_2024-10-01.pdf (97.5 KB)
The PDF has better quality
every layer must be separated. You certainly do not want the screen printing to turn into copper
PCB_PCB_Arudino-shield_2024-10-01-.zip (7.2 KB)
It depends on which CAD package you are using.
You mean, input a PDF or PNG and then obtain an SVG or STL file? No, I don't think so. Once it's a bitmap, you can't easily go back to vector.
"pdf24 creator" software able to convert PDF to SVG. look post#2.
bitmap(bmp,png,jpg,...) can be convert with Inkscape to SVG
It's not really for important purposes, just to overlay it on a 3d block so i can make a custom case. All components are thru hole, so no need for dual layer picture
so you needed only dimension layer to print
Uhh.... i dont know what a dimension letter is
Oh no...
i need the holes on the pcb
also whenever I try to add your svg onto tinkercad, it says "Tinkercad could not find any elements"
Hey guys, just found a solution to this problem. I used this website to convert my SVG to an STL which is liked by tinkercad. https://svg2solid.rknt.de/
TinkerCAD ? learning platform for kids?
i using OpenSCAD when need 3D model, just import( *.SVG) and linear_extrude.
1.svg must be in C:/Program Files folder
i am a kid
I tried to import an svg to the Open SCAD but i am unable to addan svg? I am on mac
i think OpenSCAD looking for a file in upper level folder of itself.
you can drop svg in OpenSCAD folder and using filename string as
linear_extrude(1)import("OpenSCAD/1.svg");
wdym?
openscad.exe is in folder OpenSCAD,
one level higher is folder Program Files,
one level higher is root folder of disk C:
could you send the stl that you made in the image above?
Unbenannt.zip (1.7 MB)
