switch case with timer help
Hi
Im making myself a arduino watering system, and i ran into some small problems. the code works just fine and doing what i want. Except one thing, if i want to interupt/stop the current state. How can i do this?
Here is my code
#include <SoftwareSerial.h>// import the serial library
SoftwareSerial bluetooth(3, 4); // RX, TX
const int relayPin =  13;
unsigned long time = millis();
char bluetoothData; // the data given from mobile app
boolean newData = false;
  bluetooth.begin(9600);
  pinMode(relayPin, OUTPUT);
  Serial.begin (9600); //uncomment for debugging
  recvOneChar();
  controlWater();
void recvOneChar() {
  if (bluetooth.available() > 0) {
    bluetoothData = bluetooth.read();
    newData = true;
void controlWater() {
  if (newData == true) {
    switch (bluetoothData) {
      case '1': { // Start watering
          digitalWrite(13, HIGH);   // turn the water on
          Serial.println("Start watering");
      case '2': { //Stop watering
          Serial.println("Stop watering");
          digitalWrite(13, LOW);    // turn the water off
      case '3': { //Water for 1 hours
          Serial.println("Water for 1 hours");
          delay(3600000);              // wait for x second
      case '4': { //Water for 2hours
          Serial.println("Water for 2 hours");
          delay(7200000);              // wait for x second
      case '5': { //Water for 3hours
          Serial.println("Water for 3 hours");
          delay(10800000);              // wait for x second
    newData = false;
"Except one thing, if i want to interupt/stop the current state."
delay(10800000);
Then don't use delay()
Can you follow this?
  GetRidOfDelay.ino
  LarryD
  Version YY/MM/DD
  1.00    17/02/01  Running code
//LED wiring:
// +5V---220 ohm resistor---LED anode---LED cathode---Arduino pin
const byte heartBeatLED            = 13;    //used to see if the sketch is blocking
const unsigned long heartBeatDelay = 100UL;
const byte myLED                   = 12;    //wired so a LOW turns the LED on
//SRAM variables
unsigned long currentMillis;
unsigned long heartBeatMillis;
unsigned long myLEDmillis;
unsigned long waitTime = 0;
unsigned long currentMicros;
byte LEDstate = 0;
//                          s e t u p ( )
  pinMode(heartBeatLED, OUTPUT);
  pinMode(myLED, OUTPUT);
  digitalWrite(myLED, HIGH);        //HIGH is LED off
} //                 E n d  o f  s e t u p ( )
//                          l o o p ( )
  currentMillis = millis(); //for milli second timing
  currentMicros = micros(); //for mirco second timing
  //HeartBeat LED, should toggle every heartBeatDelay milliseconds if code is nonblocking
  if (currentMillis - heartBeatMillis >= heartBeatDelay)
    heartBeatMillis = heartBeatMillis + heartBeatDelay; //reset timing
    //Toggle heartBeatLED
    digitalWrite(heartBeatLED, !digitalRead(heartBeatLED));
  //swap the comment marks // on the next two lines to see a comparison
  //usingDelay();
  usingMillis();
} //                    E n d  o f  l o o p ( )
//                        F U N C T I O N S
//                     u s i n g D e l a y ( )
void usingDelay()
  digitalWrite(myLED, LOW);  //LOW  is LED on
  delay(2000);
  delay(250);
}//                E n d  o f  u s i n g D e l a y ( )
//                     u s i n g M i l l i s ( )
void usingMillis()
  //is it time to process the next state code?
  if (currentMillis - myLEDmillis < waitTime)
    //No, it is not time
    return;
  //Yes, it is now time
  myLEDmillis = currentMillis;     //reset timing
  //state code
  switch (LEDstate)
    case 0:
      digitalWrite(myLED, LOW);    //turn LED on
      LEDstate = 1;                //next state
      waitTime = 2000UL;           //setup the wait value
    case 1:
      digitalWrite(myLED, HIGH);   //turn LED off
      LEDstate = 2;                //next state
      waitTime = 1000UL;           //setup the wait value
    case 2:
      LEDstate = 3;                //next state
      waitTime = 500UL;            //setup the wait value
    case 3:
      LEDstate = 0;                //next state
      waitTime = 250UL;            //setup the wait value
  } //End of switch/case
}//                E n d  o f  u s i n g M i l l i s ( )
//                        E N D  O F  C O D E
I see an unsigned long time variable declared but not used, did you copy code and then pared it down to reduce functionality and threw in delay yourself?
INTP:
I tried to use some timers, but i dint get it to work as i wanted. Just forgot to delete it.
larryd:
delay(10800000);
So something like this? I tried on case 3, just for checking.
unsigned long mywatermillis;
  recvOneChar();
  controlWater();
    newData = true;
          // wait for a second
          if (currentMillis - mywatermillis < 5000)
            return;
          Serial.println("Done watering");
          mywatermillis = currentMillis;     //reset timing
    newData = false;
You may need to ditch the switch case since you'll need to run condition checks to use timing. I'm not sure what the limitations are within switch case, I could be wrong. But going to if statements might be more intuitive for letting the program loop and check instead of following the case and breaking each time.
To time, you set a variable such as startTime, when the pump turns on, equal to millis() that always returns the current count. Then your program is allowed to run until you interrupt it or if an interval variable such as elapsedTime, which will equal millis() minus startTime exceeds whatever duration you wanted- the number currently in delay.
You are getting close.
Can you follow this part of the sketch?
void usingMillis()
    return;
  //state code
  switch (LEDstate)
    case 0:
    case 1:
    case 2:
    case 3:
This should be close:
My mistake, changes coming.
Phone call, I think this will work.
Do you understand how it works?
void controlWater()
    //cancel the timer as a new command has come in
    waitTime = 0;
    newData = false;
    return;
    case '1':
        // Start watering
        waitTime = 0;
    case '2':
        //Stop watering
        waitTime = 0;
    case '3':
        //Water for 1 hour
        Serial.println("Water for 1 hour");
        waitTime = 60 * 60 * 1000ul;
        //delay(3600000);              // wait for x second
        //digitalWrite(13, LOW);    // turn the water off
        //going to stop watering after time out
        bluetoothData = 2;
    case '4':
        //Water for 2 hours
        waitTime = 2 * 60 * 60 * 1000ul;
        //delay(7200000);              // wait for x second
        bluetoothData = 2;
    case '5':
        //Water for 3hours
        waitTime = 3 * 60 * 60 * 1000ul;
        //delay(10800000);              // wait for x second
        bluetoothData = 2;
  } //END of switch/case
} //END of function
larryd:
delay(10800000);
  recvOneChar();
  controlWater();
    newData = true;
            return;
    newData = false;
larryd:
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        // Start watering
        waitTime = 0;
case '2':
        //Stop watering
        waitTime = 0;
case '3':
        //Water for 1 hour
        bluetoothData = 2;
case '4':
        //Water for 2 hours
        bluetoothData = 2;
case '5':
        //Water for 3hours
        bluetoothData = 2;
} //END of function
Just tried this, but it does not turn the relayPin of after waitTime.
How did you test the time out as it is set to 1, 2, 3 hours?
larryd:
Just changed it to 10sec
Please show us your current sketch.
larryd:
  recvOneChar();
  controlWater();
    newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        // Start watering
        waitTime = 0;
    case '2':
        //Stop watering
        waitTime = 0;
    case '3':
        //Water for 1 hour
        waitTime = 10000ul;
        Serial.println("Watering done");
        //stop watering
        bluetoothData = 2;
    case '4':
        //Water for 2 hours
        //stop watering
        bluetoothData = 2;
    case '5':
        //Water for 3hours
        //stop watering
        bluetoothData = 2;
} //END of function
A few problems 8)
bluetoothData = 2;
Should have been:
bluetoothData = '2';
Not able to check this here, but try:
unsigned long myRelayMillis;
  recvOneChar();
  controlWater();
    newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
  if (currentMillis - myRelayMillis < waitTime)
    return;
    case '1':
        // Start watering
        myRelayMillis = millis();
        waitTime = 0;
    case '2':
        //Stop watering
        waitTime = 0;
    case '3':
        //Water for 1 hour
        waitTime = 10000ul;
        //stop watering
    case '4':
        //Water for 2 hours
        //stop watering
    case '5':
        //Water for 3hours
        //stop watering
} //END of function
larryd:
A few problems 8)
bluetoothData = 2;
Should have been:
  recvOneChar();
  controlWater();
    newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        // Start watering
        waitTime = 0;
case '2':
        //Stop watering
        waitTime = 0;
case '3':
        //Water for 1 hour
        waitTime = 10000ul;
        //stop watering
case '4':
        //Water for 2 hours
//stop watering
case '5':
        //Water for 3hours
//stop watering
} //END of function
just tried it, but same as before. Does not stop timer.
Again, I cannot check this, but try try again:
  recvOneChar();
  controlWater();
void recvOneChar()
    newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        // Start watering
        waitTime = 5000;
    case '2':
        //Stop watering when timing is over
        waitTime = 5000;
    case '3':
        //Water for 1 hour
        waitTime = 10000ul;
    case '4':
        //Water for 2 hours
    case '5':
        //Water for 3hours
} //END of function
larryd:
recvOneChar();
  controlWater();
void recvOneChar()
    newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        // Start watering
waitTime = 5000;
case '2':
waitTime = 5000;
case '3':
        //Water for 1 hour
        waitTime = 10000ul;
case '4':
        //Water for 2 hours
case '5':
        //Water for 3hours
} //END of function
Not working :sob:
I think we are close, I'll power up the equipment and try things here.
Hold on. . . .
Made some cosmetic changes.
However, I tried it here, things work with using simple button switches to change the cases as I don't have a Bluetooth module right now.
Try this again, make sure you upload it to the Arduino.
  recvOneChar();
  controlWater();
void recvOneChar()
    newData = true;
void controlWater()
    waitTime = 0;
    newData = false;
    return;
    case '1':
        //Start watering
        waitTime = 5000;
    case '2':
        waitTime = 5000;
    case '3':
        //Water for 1 hour
        waitTime = 5000ul;  //testing
        //waitTime = 1 * 60 * 60 * 1000ul;
    case '4':
        //Water for 2 hours
        //waitTime = 10000;  //testing
    case '5':
        //Water for 3hours
        //waitTime = 15000;  //testing
} //END of function
