Switching 12V 3A from a 3.3V GPIO
I would like to switch a PAM8610 audio amplifier board with a Wemos D1 mini. It takes 12V in and produces 20 W of sound. I power it with a 12V 3A wallwart.
In the past I've switched a 5v fan from a Pi using an S8050. Can do something similar with a larger transistor?
I'm an electronics novice. Whats the simplest solution?
Simplest is a relay module. Perhaps more elegant is a p-MOSFET driven from an NPN transistor,
see post #4 here: Using High side mosfet switching for high current apps - General Electronics - Arduino Forum
Thanks. Is there any reason to prefer a high side switch to a low side switch?
