Take picture with fswebcam [Solved]
Hello,
I am trying to get a picture with my webcamera from the Yun.
cd /mnt/sda1/
And there is the error
--- Opening /dev/video0...
stat: No such file or directory
the fswebcam is trying to find the /dev/video0 there is not something like this at my /dev.
But with lsusb I can see the camera and it is /dev/bus/usb/001/003.
when I try
fswebcam 1.jpg -d /dev/bus/usb/001/003
--- Opening /dev/bus/usb/001/003...
Trying source module v4l2...
/dev/bus/usb/001/003 opened.
/dev/bus/usb/001/003: Not a V4L2 device?
Trying source module v4l1...
/dev/bus/usb/001/003: Not a V4L device?
VIDIOCGCAP: Inappropriate ioctl for device
/dev/bus/usb/001/003 closed.
Unable to find a source module that can read /dev/bus/usb/001/003.
what can I do?
(From my debian I can take picture with this camera with the same way)
my camera is LifeCam VX-3000
edit: I found an other camera and got a picture, but the quality is very low (2/10)
I am lost now
I have the same problem that I have asked and still did not find the solution:
bolatu:
Hi guys,
I have a problem about taking picture from my Logitech HD Webcam C270. I have installed everything properly. However, I have this error when I want to take a picture:
root@Arduino:~# cd /mnt/sda1
root@Arduino:/mnt/sda1# fswebcam test.png
/dev/video0 opened.
No input was specified, using the first.
Adjusting resolution from 384x288 to 352x288.
--- Capturing frame...
VIDIOC_DQBUF: No such device
No frames captured.
root@Arduino:/mnt/sda1# cd
root@Arduino:~# fswebcam --no-banner --save photo.jpg
/dev/video0 opened.
Unable to find a compatible palette format.
/dev/video0 opened.
I have checked my systemlog and it didnt recognize my webcam:
Jul  4 00:56:16 Arduino kern.info kernel: [ 1211.550000] uvcvideo: Found UVC 1.00 device (046d:0825)
Jul  4 00:56:16 Arduino kern.info kernel: [ 1211.650000] input: UVC Camera (046d:0825) as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1:1.0/input/input131
Jul  4 00:56:25 Arduino kern.info kernel: [ 1220.940000] usb 1-1.1: USB disconnect, device number 25
Jul  4 00:56:25 Arduino kern.info kernel: [ 1221.190000] usb 1-1.1: new high-speed USB device number 26 using ehci-platform
Jul  4 00:56:25 Arduino kern.info kernel: [ 1221.530000] usb 1-1.1: New USB device found, idVendor=046d, idProduct=0825
Jul  4 00:56:25 Arduino kern.info kernel: [ 1221.530000] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Jul  4 00:56:25 Arduino kern.info kernel: [ 1221.540000] usb 1-1.1: SerialNumber: F4C44090
Jul  4 00:56:26 Arduino kern.info kernel: [ 1221.550000] uvcvideo: Found UVC 1.00 device (046d:0825)
Jul  4 00:56:26 Arduino kern.info kernel: [ 1221.650000] input: UVC Camera (046d:0825) as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1:1.0/input/input132
Jul  4 00:56:30 Arduino kern.info kernel: [ 1225.550000] usb 1-1.1: USB disconnect, device number 26
fswebcam  -i 0 -d v4l2:/dev/video0  --no-banner  --jpeg 95  --save test.jpg
--jpeg 95 will increase quality to 95%.
From my debian I can take picture with this camera with the same way my camera is LifeCam VX-3000
Make sure driver installed:
root@Arduino:/mnt/sda1# ls /dev/video0  -al
crw-r--r--    1 root     root       81,   0 Jul  7 07:08 /dev/video0
Test device :
root@Arduino:/mnt/sda1# fswebcam -d v4l2:/dev/video0 -i 0 --list-controls
--- Opening v4l2:/dev/video0...
/dev/video0 opened.
Available Controls        Current Value   Range
Brightness                64 (100%)       -64 - 64
Contrast                  15 (50%)        0 - 30
Saturation                50 (39%)        0 - 127
Hue                       0 (50%)         -16000 - 16000
White Balance Temperature, Auto True            True | False
Gamma                     100 (34%)       20 - 250
Power Line Frequency      60 Hz           Disabled | 50 Hz | 60 Hz
White Balance Temperature 5000 (59%)      2800 - 6500
Sharpness                 35 (35%)        0 - 100
Backlight Compensation    0               0 - 1
Captured frame in 0.00 seconds.
--- Processing captured image...
There are unsaved changes to the image.
LifeCam VX-3000 might not be UVC device.
http://forum.arduino.cc/index.php?topic=244334.msg1749411#msg1749411
opkg update
opkg install kmod-usb-core kmod-video-core kmod-input-core
opkg remove kmod-video-uvc
opkg install kmod-video-gspca-core
opkg install kmod-video-gspca-sonixj
@bolatu;-
Logitech HD Webcam C270 is UVC device.
sonnyyu:
For UVC webcam;-
opkg update
opkg install kmod-usb-core kmod-video-core kmod-input-core kmod-video-uvc
some time reboot is needed.
then same as above test driver installed and test device.
sonnyyu:
opkg update
with the other camera I can take picture but still the 95 didn't help. Too low quality.
with ls /dev/video0 -al
I can see the driver as you say.
Sometimes I get a full black picture.
also I get the warning
gd-jpeg: JPEG library reports unrecoverable error: Not a JPEG file: starts with 0x16 0x81
Back to VX-3000
I tried to install kmod-video-gspca-sonixj. Sonixj is my driver always from this list
045E:00F5 kmod-video-gspca-sonixj
but I get this error
root@Arduino:~# opkg install kmod-video-gspca-sonixj
Unknown package 'kmod-video-gspca-sonixj'.
Collected errors:
 * opkg_install_cmd: Cannot install package kmod-video-gspca-sonixj.
Collected errors:
opkg update
/dev/video0 opened.
Increase brightness by
fswebcam   -i 0 -d /dev/video0  --set brightness=100%
same way to adjust Contrast, Saturation, Hue, Sharpness...
root@Arduino:/mnt/sda1/test# opkg list-installed |grep kmod-video-*
kmod-video-core - 3.3.8-1
kmod-video-uvc - 3.3.8-1
kmod-video-videobuf2 - 3.3.8-1
found out all the installed video kernel driver, remove them all then install correct one again. reboot will help since you are working on kernel.
use "--save test.jpg" will help.
sonnyyu:
/dev/video0 opened.
removed all then installed correct one again and still getting the same error after
opkg update
"--save test.jpg" helped.
Increased brightness but some times all is black and some times I get the picture, maybe it is something wrong with my board? Should I reset it to the factory default?
Never hurt, I reset it to the factory default every few days anyway.
Ok, Reset is done.
1)Installed fswebcam
2)
$ opkg update
$ opkg install kmod-video-uvc
and here we go,
everything is black
my camera is Logitech C170
I checked the system log and there is
Jul  7 20:45:03 Yun authpriv.notice dropbear[4007]: Password auth succeeded for 'root' from 192.168.10.11:35783
Jul  7 20:49:01 Yun kern.info kernel: [  611.200000] uvcvideo: Found UVC 1.00 device Webcam C170 (046d:082b)
Jul  7 20:49:01 Yun kern.info kernel: [  611.220000] input: Webcam C170 as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1:1.0/input/input1
Jul  7 20:49:01 Yun kern.info kernel: [  611.220000] usbcore: registered new interface driver uvcvideo
Jul  7 20:49:01 Yun kern.info kernel: [  611.220000] USB Video Class driver (1.1.1)
I think I found the solution,
the problem was the frames.
The camera gives black because it cant take a picture with one frame.
You have to:
1)skip the first frames with the -S 10
2)or take the pictures with more frames -F 10 (range 1-255) 255 is slow
3) or give more power to camera (usb hub)
so this can give a normal picture. XD
fswebcam  -i 0 -d v4l2:/dev/video0  --jpeg 95  --save test.jpg -S 20 -r 640x480
Well done. Can you change the topic title to "solved" ?
Well,
updated to OpenWRTYun and LifeCam VX-3000 worked.
sonnyyu:
@bolatu;-
Hello,
I am having the same trouble and with a camera C270. My question is, with this code, can fix the problem?
what is --jpeg 95 ?
