Hello everyone,
I've been having an issue getting my teensy to talk to glediator, because I want to use to run a basic homemade neopixel matrix. (neopixel strandtest and Fast_LED, run without an itch)
so far
• I have installed the right rxtx lib file,
• I can see the the teensy COM-Port of Glediator,
When I activate the serial, I can see that the teensy is receiving some data or something, because the orange light blinks like crazy, I have tried every pins but no luck,
I can't figure out where the problem originate from, maybe someone here can tell me what I'm not doing right,
Thanks in advance,
video: - YouTube
here's the sketch I'm using
// Matrix size 80 (10x8)
#define Num_Pixels 80
// Pinout on Teensy 3.0/3.1> Clock=13 Data=11
#define CMD_NEW_DATA 1
int SDI = 11;
int CKI = 13;
unsigned char display_buffer[Num_Pixels * 3];
static unsigned char *ptr;
static unsigned int pos = 0;
volatile unsigned char go = 0;
pinMode(SDI, OUTPUT);
pinMode(CKI, OUTPUT);
Serial.begin(9600); // USB is always 12 Mbit/sec
if (0<usb_serial_available()){
unsigned char b;
b = usb_serial_getchar();
if (b == CMD_NEW_DATA) {pos=0; ptr=display_buffer; return;}
if (pos == (Num_Pixels*3)) {} else {*ptr=b; ptr++; pos++;}
if (pos == ((Num_Pixels*3)-1)) {go=1;}
if (go==1) {shift_out_data(); go=0;}
Serial.println(display_buffer[100]);
// Shift out Data #
void shift_out_data()
for (int i=0; i<Num_Pixels; i++)
byte r = display_buffer[i*3+0];
byte g = display_buffer[i*3+1];
byte b = display_buffer[i*3+2];
for (byte j=0; j<8; j++)
digitalWrite(CKI, LOW);
if (r & (byte)(1<<(7-j))) {digitalWrite(SDI, HIGH);} else {digitalWrite(SDI, LOW);}
digitalWrite(CKI, HIGH);
if (g & (1<<(7-j))) {digitalWrite(SDI, HIGH);} else {digitalWrite(SDI, LOW);}
if (b & (1<<(7-j))) {digitalWrite(SDI, HIGH);} else {digitalWrite(SDI, LOW);}
delayMicroseconds(800); //Latch Data
the pin I connect the teensy to is pin 1 ( I have tried all other pins but there's no comm)
