Everything I try to build ends up with the following errors. I have no clue...
Serial.printf ("start\n");
Serial.printf ("run\n");
FQBN: teensy:avr:teensy41:opt=o3lto
Using board 'teensy41' from platform in folder: /Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0
Using core 'teensy4' from platform in folder: /Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0
Detecting libraries used...
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4 /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch/sketch_apr16a.ino.cpp -o /dev/null
Generating function prototypes...
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4 /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch/sketch_apr16a.ino.cpp -o /private/var/folders/4f/gbtv394d4fz860b3j_pxd6w80000gn/T/1452031854/sketch_merged.cpp
/Users/loren/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/4f/gbtv394d4fz860b3j_pxd6w80000gn/T/1452031854/sketch_merged.cpp
Compiling sketch...
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-tools/1.59.0/precompile_helper /Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4 /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062 /Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-g++ -x c++-header -O3 -flto -fno-fat-lto-objects -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4 /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/pch/Arduino.h -o /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/pch/Arduino.h.gch
Using previously compiled file: /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/pch/Arduino.h.gch
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-g++ -c -O3 -flto -fno-fat-lto-objects -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/pch -I/Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4 /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch/sketch_apr16a.ino.cpp -o /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch/sketch_apr16a.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /Users/loren/Library/Caches/arduino/cores/teensy_avr_teensy41_usb_serial,speed_600,opt_o3lto,keys_en-us_f3d4898dac4721833db61233c4186133/core.a
Linking everything together...
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-gcc -O3 -flto -fno-fat-lto-objects -Wl,--gc-sections,--relax -T/Users/loren/Library/Arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/imxrt1062_t41.ld -fuse-linker-plugin -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch_apr16a.ino.elf /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch/sketch_apr16a.ino.cpp.o /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/../../cores/teensy_avr_teensy41_usb_serial,speed_600,opt_o3lto,keys_en-us_f3d4898dac4721833db61233c4186133/core.a -L/Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062 -larm_cortexM7lfsp_math -lm -lstdc++
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: address 0xc0 of /Users/loren/Library/Caches/arduino/sketches/21E343C3D25138E4028095ECFF59C062/sketch_apr16a.ino.elf section `.bss' is not within region `DTCM'
/Users/loren/Library/Arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: warning: cannot find entry symbol ImageVectorTable; not setting start address
collect2: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
