temperature Fan drive
I have a Thermocouple sensor, Button Array, Led Display and a fan.
I"v setup two Situations that I can select by bottom 1 and 2 from 5 Buttom Array
In first Scenario Fan changes Speed at 27C in second scenario at 40C. My Projects
works to a degree. I have 3 Buttoms left and I would like to use them to change
triggering temperature on the fly and not with Code
Here is the Code:
#include "max6675.h"
#include "TM1637.h"
//{0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
//0~9,A,b,C,d,E,F
int thermoDO = 6;
int thermoCS = 5;
int thermoCLK = 4;
#define CLK 2       //Pins for TM1637
#define DIO 3
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
TM1637 tm1637(CLK, DIO);
const int motorPin = 7;      // the motor pin
const int dirPin = 8;         // the motor direction change pin
volatile int inputPin = A0;  // buttons array analog input
uint16_t inputValue = 0;   // value read from buttons array
int lastValue = 0;        //saved value
  Serial.begin(9600); // Serial is used to print sensor readings.
  tm1637.init();
  tm1637.set(BRIGHT_DARKEST);
  //BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
  pinMode(motorPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  int inputValue = 0;
  delay(2500);
  // check buttons status
  inputValue = analogRead(inputPin);
  if (inputValue < 100 && inputValue >= 0) inputValue = 29;
  else if (inputValue < 250 && inputValue > 150) inputValue = 40;
  else if (inputValue < 470 && inputValue > 370) inputValue = 251;
  else if (inputValue < 670 && inputValue > 570) inputValue = 252;
  else if (inputValue < 870 && inputValue > 770) inputValue = 254;
else if (inputValue <= 1023 && inputValue > 950) inputValue = 255;
  if (inputValue != 255) {
    lastValue = inputValue;}
 Serial.println(inputValue);
  Serial.println(lastValue);
  int temp = thermocouple.readCelsius();
  int digitoneT = temp / 10;
  int digittwoT = temp % 10;
  tm1637.display(0, digitoneT);
  tm1637.display(1, digittwoT);
  Serial.println(temp);
  if (temp >= lastValue && temp != 0) {
    analogWrite(motorPin, 255);
  else if (temp <= lastValue && lastValue != 0)
  { analogWrite(motorPin, 100);
  else if (lastValue == 0)
  { analogWrite(motorPin, 0);
  else if (lastValue == 255)
  { analogWrite(motorPin, 255);
  if (lastValue == 29) {
    tm1637.display(3, 11); // put a B at the end
    delay(100);
  else if (lastValue == 40) {
    tm1637.display(3, 10); // put a ABS at the end
    delay(100);
novio8:
Here is the Code:
#include "TM1637.h"
//0~9,A,b,C,d,E,F
int thermoDO = 6;
int thermoCS = 5;
int thermoCLK = 4;
#define DIO 3
tm1637.init();
  int inputValue = 0;
  delay(2500);
    delay(100);
delay(100);
I almost ignored your post, but came back. IF you don't want to use "code" with the additional switches, why did you include your "code"? What am I missing?
Paul
what I meant is that I programmed two temperatures for
first two momentary switches
but I want to use the rest of momentary switches to change temperature
So one up and the other down
