What is my code missing?
//My project is a temperature-based, variable-speed fan with two LEDs, controlled by an Arduino Uno. We were given partial code, and now we must declare an integer, which I did, and now I need to light up the diodes. Fan on is the green LED, fan off is the blue LED. I have to make them light up respectively, but I must be missing those lines of code. A little help please?
// C++ code
//Pin Variables
int tempPin = 1;
int tempVal = 0;
int enable = 6;
int dirA = 5;
int dirB = 3;
int motorSpeed = 128;
int fanOnLED = 13;
int fanOffLED = 11;
    pinMode(enable, OUTPUT);
    pinMode(dirA, OUTPUT);
    pinMode(dirB, OUTPUT);
    digitalWrite(enable, LOW);
    digitalWrite(dirA, LOW);
    digitalWrite(dirB, LOW);
    digitalWrite(fanOnLED, LOW);
    digitalWrite(fanOffLED, LOW);
    // Read the value of the temperature sensor
    tempVal = analogRead(tempPin);
    // Calculate the sensor reading into millivolts
    float mV = (5000.0 * tempVal)/1024;
    // Calculate the temperature in Centigrade
    float tempC = (mV - 500)/10;
    // Print the temperature to the serial monitor
    Serial.print("Temperature in C: ");
    Serial.print(tempC);
    delay(100);
    // If the temperature goes above 25 degrees C, start the fan
    if (tempC > 25.0) {
    spinMotor(motorSpeed);
    // If the temperature drops below 25 degrees C, stop the fan
    else {
    spinMotor(0);
void spinMotor(int motorSpeed) {
    // Set motors to maximum speed
    // For PWM maximum possible values are 0 to 255
    // Spin the motor forward
    analogWrite(enable,abs(motorSpeed));
    digitalWrite(dirA, HIGH);
// Can someone help?
This sounds like a course project, is it? What grade level?
Do you mean "if fan on, green on and blue off" and "if fan off, green off and blue on?"
Don't forget to pinMode the LED pins to OUTPUT in setup();
    pinMode(fanOnLED, OUTPUT);
    pinMode(fanOffLED, OUTPUT);
Internet of Things - Connecting Things, at Cuyamaca College. I'm doing it on TinkerCAD.
