Temperature relaying information
 *     |  Arduino Experimentation Kit Example Code             |
 *     |  CIRC-10 .: Temperature :. (TMP36 Temperature Sensor) |
 *  A simple program to output the current temperature to the IDE's debug window
//TMP36 Pin Variables
int temperaturePin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade
                        //(500 mV offset) to make negative temperatures an option
 * setup() - this function runs once when you turn your Arduino on
 * We initialize the serial connection with the computer
  Serial.begin(9600);  //Start the serial connection with the copmuter
                       //to view the result open the serial monitor
                       //last button beneath the file bar (looks like a box with an antenae)
void loop()                     // run over and over again
 float temperature = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
 temperature = (temperature - .5) * 100;          //converting from 10 mv per degree wit 500 mV offset
                                                  //to degrees ((volatge - 500mV) times 100)
 Serial.println(temperature);                     //printing the result
 delay(1000);                                     //waiting a second
 * getVoltage() - returns the voltage on the analog input defined by
 * pin
float getVoltage(int pin){
 return (analogRead(pin) * .004882814); //converting from a 0 to 1024 digital range
                                        // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
I have recently purchased an arduino kit from oomlout. They provided some examples and I am wondering how I would go about editing this code so when the temperature reach's a certain temperature then it turns on the on board led in pin 13. Many thanks,
Jordan
added a little code to yours to do what you wanted hope this is it
//___________________________________________
#define LEDPIN 13 // ledpin which you will output to
#define TEMPTRIGGER 50.05 // tempreture at which led will turn on
pinMode(LEDPIN,OUTPUT)
//__________EDIT______EDIT______EDIT______EDIT______
if(temperature>=TEMPTRIGGER){
digitalWrite(LEDPIN, HIGH);}
//turns on pin assigned to LED for the one on the board set LEDPIN to
//use 13
else{
digitalWrite(LEDPIN, LOW);//turns off the LED if temp is < TEMP TRIGGER
 * pin
Thanks that worked absoloutely great!
