Hi friends,
With the assistance of more experienced members, I finally achieved what I aimed to.
I am using three sensors DS18B20 to monitor temperature at different locations.
The code & hardware are running satisfactorily faultless for several days so far.
Having the Arduino & coding with unlimited functions, I wish to add one more task to the code.
New condition:-
While the loop is running, if at anytime the freezer temperature measured ≥5°C for more than 5 minutes, the code will change the status of a free output (53,HIGH). This output condition should remain HIGH until dropping < 5°C to become (53,LOW) & so on.
With my limited experience & avoiding to mess-up the code, I need your help to validate the above mentioned new condition among the below code.
The code without the new condition:-
#include <DallasTemperature.h> //library for DS18B20 sensors & it includes LCD
OneWire oneWire1(52); //room temperature sensor
DallasTemperature sensors1(&oneWire1);
OneWire oneWire2(24); //fridge temperature sensor
DallasTemperature sensors2(&oneWire2);
OneWire oneWire3(22);//freezer temperature sensor
DallasTemperature sensors3(&oneWire3);
const int compressorRelay = 25;
const int defrostRelay = 23;
unsigned long previousMillisStartdefrosting;
unsigned long previousMillisDefrosting;
unsigned long previousMilliscounter;
bool Startdefrosting = false;
bool Defrosting = false;
bool enablereading = false;
int counter =0; //one counter with two actions
float countertime=0;
float totaltime;
#include <LiquidCrystal.h>
//LCD keypad shield setup pins
const int pin_RS = 8;
const int pin_EN = 9;
const int pin_d4 = 4;
const int pin_d5 = 5;
const int pin_d6 = 6;
const int pin_d7 = 7;
const int pin_BL = 10;
LiquidCrystal lcd( pin_RS, pin_EN, pin_d4, pin_d5, pin_d6, pin_d7);
extern volatile unsigned long timer0_millis;
int totalColumns = 16;
int totalRows = 2;
String scrollingMessage = "Three temperature sensors 10/10/2023;room, fridge, freezer & total operating time controller...";
void scrollMessage(int row, String message, int delayTime, int totalColumns) {
for (int i=0; i < totalColumns; i++) {
message = " " + message;
message = message + " ";
for (int position = 0; position < message.length(); position++) {
lcd.setCursor(0, 0);
lcd.print(message.substring(position, position + totalColumns));
delay(delayTime);
void setup(void)
lcd.begin(16, 2);
lcd.print("SETUP CONTROLLER");
delay(1500);
lcd.setCursor(0, 1);
lcd.print("......WAIT......");
delay(1500);
Serial.println("Measuring 3 sensors' temperatures");
pinMode( compressorRelay, OUTPUT);
pinMode (defrostRelay, OUTPUT);
sensors1.begin();
sensors2.begin();
sensors3.begin();
void loop(void)
digitalWrite( compressorRelay, LOW);
digitalWrite (defrostRelay, LOW);
//delay(500);
delay(5000); // a delay to absorb any power fluctuations on startup
label:
totaltime = (countertime * 300000) +millis();
//millis reset to avoid overflow (to be 20 days in milliseconds)
if(millis() >= 300000)
{noInterrupts ();
countertime ++;
timer0_millis=0;
previousMilliscounter=0;
previousMillisDefrosting=0;
previousMillisStartdefrosting=0;
currentMillis=0;
interrupts();}
sensors1.requestTemperatures();
sensors2.requestTemperatures();
sensors3.requestTemperatures();
float room = sensors1.getTempCByIndex(0);
float fridge = sensors2.getTempCByIndex(0);
float freezer= sensors3.getTempCByIndex(0);
//sensor reading display delay
if( currentMillis - previousMillisDefrosting >= 2000){
enablereading = !enablereading;
previousMillisDefrosting = currentMillis;
if(enablereading){
Serial.print("room=");
Serial.print(room);
Serial.print(", ");
Serial.print("fridge=");
Serial.print(fridge);
Serial.print(", ");
Serial.print("freezer=");
Serial.print(freezer);
Serial.print(", ");
Serial.print("m=");
Serial.print(millis());
Serial.print(", ");
Serial.print("cm=");
Serial.print(currentMillis);
Serial.print(", ");
Serial.print("pmsd=");
Serial.print(previousMillisStartdefrosting);
Serial.print(", ");
Serial.print("pmd=");
Serial.print(previousMillisDefrosting);
Serial.print(", ");
Serial.print("sd=");
Serial.print(Startdefrosting);
Serial.print(", ");
Serial.print("total time=");
Serial.print(totaltime/60000);
Serial.print("min");
lcd.clear();
lcd.print("....GOOD DAY....");
lcd.clear();
lcd.clear();
lcd.clear();
lcd.clear();
scrollMessage(1, scrollingMessage, 250, totalColumns); //scrollMessage(int row, String message, int delayTime, int totalColumns)
lcd.setCursor(0,0);
lcd.print("Time in hours ");
lcd.setCursor(14,1);
//lcd.print((char)223);
lcd.setCursor(0,1);
lcd.print("Temp.-55to+125 C");
lcd.setCursor(14,1); //column,row
delay(3000);
lcd.setCursor(0,0);
lcd.print("Room = C");
lcd.setCursor(14,0); //column,row
lcd.setCursor(8,0);
lcd.print(room);
lcd.setCursor(0,1);
lcd.print("Fridge = C");
lcd.setCursor(8,1);
lcd.print(fridge);
delay(5000);
lcd.setCursor(0,0);
lcd.setCursor(8,0);
lcd.print(fridge);
lcd.setCursor(0,1);
lcd.print("Freezer= C");
lcd.setCursor(8,1);
lcd.print(freezer);
delay(5000);
lcd.setCursor(0,0);
lcd.setCursor(8,0);
lcd.print(freezer);
lcd.setCursor(0,1);; //column/row
lcd.print("Time= Hr");
lcd.setCursor(5,1); //column/row
lcd.print(totaltime/3600000);
delay(5000);
lcd.setCursor(0,0); //column/row
lcd.setCursor(5,0); //column/row
// delay(5000);
lcd.setCursor(0,1);
lcd.setCursor(8,1);
lcd.print(room);
delay(2000);
if(!enablereading) {
lcd.setCursor(0,0);
lcd.setCursor(8,0);
lcd.print(room);
//delay(2000);
lcd.setCursor(0,1);
lcd.setCursor(8,1);
lcd.print(fridge);
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(8,0);
lcd.print(fridge);
lcd.setCursor(0,1); //column/row
lcd.setCursor(0,1);
lcd.setCursor(8,1);
lcd.print(freezer);
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(8,0);
lcd.print(freezer);
//delay(2000);
delay(3000);
lcd.setCursor(0,1);
lcd.setCursor(8,1);
lcd.print(room);
delay(3000);
/*energize defrostRelay led once every 24 hours each for ??? minutes
without affecting lcd display scrolling text or
compressorRelay
led functionality
below line represents the 24 hour timer during which an action will start & stop once
& one counter to count two actions on/off*/
if(currentMillis - previousMilliscounter >= 26000){
counter = 2;
previousMilliscounter= currentMillis;}
// defrostRelay led ON period
if ( currentMillis - previousMillisStartdefrosting >= 2000 && (counter == 2 || counter == 1) )
counter --;
, LOW);
previousMillisStartdefrosting = currentMillis;
Startdefrosting = !Startdefrosting;
if( !Startdefrosting)
digitalWrite( defrostRelay, LOW); }
if((freezer>=0))
digitalWrite(defrostRelay,LOW);
, HIGH);
lcd.clear();
lcd.setCursor(0,0); //column,row
lcd.print("..COOLING DOWN..");
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
lcd.print("....COOLING....");
delay(1500);
// lcd.setCursor(0,0); //column,row
//lcd.print("Time= Hr");
if((freezer<-10 && freezer<0) && digitalRead(defrostRelay) == LOW )
{digitalWrite( compressorRelay , HIGH);}
if((freezer<-10 ))
{digitalWrite( compressorRelay , LOW);}
if( Startdefrosting)
digitalWrite( compressorRelay ,LOW);
digitalWrite( defrostRelay,HIGH);
lcd.clear();
lcd.print("...DEFROSTING...");
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
delay(300);
lcd.clear();
delay(300);
goto label;
