Hi, complete newbie here. Sorry for any mistakes/missing information, please update me and I will include it. I don't really remember/know much about PID usage either, sorry about that.
Currently, I amm referencing the filament extrusion machine code from Electronoobs at: Electronoobs Video.
If I missed out on providing any basic details, perhaps some of these details can be found here on his blog at:
Electronoobs Blog
I have assembled the PCB along with corresponding hardware and am currently using the hardware as follows:
Arduino Nano
Nema 17 Motor
12V 40W heating element and thermistor
LCD display
12V 5A power supply
Just one single push button, Button 1 that starts/stops the motor
I do NOT have the potentiometer soldered on top of the Arduino, I do not trust my soldering skills for this task.
I am facing two problems:
The motor appears to be rotating very slowly, supposedly due to the lines of code governing the LCD behavior. If I use a 250ms delay, then it takes 4 steps per second, once every 0.25s. Currently, I am using a 100ms delay at "800 rpm", but it is still terribly slow. Is my understanding even correct here?
The temperature set point for the heating element and thermistor pair does not appear to work. I set the setpoint to 220C, it heated up to 240C and showed no signs of stopping. I have no idea what is causing this. Is it simply unsuitable PID constants?
I would like to:
- set the motor to run at a specific speed which I can have greater control over
- set the heating element to reach towards and maintain temperature at the point I set.
Please, any insight or guidance at all would be very valuable. Please advise, and thank you very much.
The code I am using is pasted as follows:
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); //sometimes the adress is not 0x3f. Change to 0x27 if it dosn't work.
//Thermistor needed libraries
#include <thermistor.h> //Download it here: https://electronoobs.com/eng_arduino_thermistor.php
thermistor therm1(A0,0); //Connect thermistor on A0, 0 represents TEMP_SENSOR_0 ( configuration.h for more)
//I/O
int PWM_pin = 5; //Pin for PWM signal to the MOSFET driver (the BJT npn with pullup)
int speed_pot = A1;
int but1 = 7;
int EN = 2;
int STEP = 3;
int DIR = 4;
int LED = 13;
//Variables
float set_temperature = 210; //Default temperature setpoint. Leave it 0 and control it with rotary encoder
float temperature_read = 0.0;
float PID_error = 0;
float previous_error = 0;
float elapsedTime, Time, timePrev;
float PID_value = 0;
int button_pressed = 0;
int menu_activated=0;
float last_set_temperature = 0;
int max_PWM = 255;
//Stepper Variables
int max_speed = 1000;
int main_speed = 0;
bool but1_state = true;
bool activate_stepper = false;
int rotating_speed = 0;
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper1(1, STEP, DIR); // (Type of driver: with 2 pins, STEP, DIR)
//PID constants
int kp = 90; int ki = 30; int kd = 80;
int PID_p = 0; int PID_i = 0; int PID_d = 0;
float last_kp = 0;
float last_ki = 0;
float last_kd = 0;
int PID_values_fixed =0;
pinMode(EN, OUTPUT);
digitalWrite(EN, HIGH); //Stepper driver is disbled
stepper1.setMaxSpeed(max_speed);
pinMode(but1, INPUT_PULLUP);
pinMode(speed_pot, INPUT);
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
pinMode(PWM_pin,OUTPUT);
TCCR0B = TCCR0B & B11111000 | B00000010; // D6 adn D6 PWM frequency of 7812.50 Hz
Time = millis();
TCCR1A = 0; //Reset entire TCCR1A register
TCCR1B = 0; //Reset entire TCCR1B register
TCCR1A |= B00000010; // /8
TCNT1 = 0; //Reset Timer 1 value to 0
lcd.init();
lcd.backlight();
if(!digitalRead(but1) && but1_state){
but1_state = false;
activate_stepper = !activate_stepper;
delay(10);
else if(digitalRead(but1) && !but1_state){
but1_state = true;
if(activate_stepper){
digitalWrite(LED, HIGH);
digitalWrite(EN, LOW); //We activate stepper driver
rotating_speed = 800;
stepper1.setSpeed(800);
stepper1.runSpeed();
digitalWrite(EN, HIGH); //We deactivate stepper driver
stepper1.setSpeed(0);
// First we read the real value of temperature
temperature_read = therm1.analog2temp(); // read temperature
//Next we calculate the error between the setpoint and the real value
PID_error = set_temperature - temperature_read + 6;
//Calculate the P value
PID_p = 0.01*kp * PID_error;
//Calculate the I value in a range on +-6
PID_i = 0.01*PID_i + (ki * PID_error);
//For derivative we need real time to calculate speed change rate
timePrev = Time; // the previous time is stored before the actual time read
Time = millis(); // actual time read
elapsedTime = (Time - timePrev) / 1000;
//Now we can calculate the D calue
PID_d = 0.01*kd*((PID_error - previous_error)/elapsedTime);
//Final total PID value is the sum of P + I + D
PID_value = PID_p + PID_i + PID_d;
//We define PWM range between 0 and 255
if(PID_value < 0){
PID_value = 0;
if(PID_value > max_PWM){
PID_value = max_PWM;
//Now we can write the PWM signal to the mosfet on digital pin D5
analogWrite(PWM_pin,PID_value);
previous_error = PID_error; //Remember to store the previous error for next loop.
delay(100); //Refresh rate + delay of LCD print
lcd.clear();
lcd.setCursor(0,0);
lcd.print("T: ");
lcd.print(temperature_read,1);
lcd.print(" S: ");
lcd.print(rotating_speed);
lcd.setCursor(0,1);
lcd.print("PID: ");
lcd.print(PID_value);
}//Void loop end
ISR(TIMER1_COMPA_vect){
TCNT1 = 0; //First, set the timer back to 0 so it resets for next interrupt
